29434 Discussions
Serious memory leak when writing data to a binary file
Ben_W_
Hi, all:
I'm having a serious memory leak problem on the WRITE statement in Intel Visual compiler version 12. As demonstrated in the following simple code, I'm trying to write about 400M binary data to a file in direct access, unformatted form. If I compile the code and run the program. I noticed that the Performance Tab in the Windows Task manager shows that the system memory usage is increased by about 400M. After a couple of minutes, the memory usage decreased and returned to the time before running the progam. So I called it a memory leak. This behavior is not accepatble in my real application because I usually write out several gigbyte of data and it uses up my system physcial memory and my application becomes very slow.
It seems that when writing to the file, Windows system caches the data in the memory first and keeps data for a while and then Release it. How can I disable this caching behavior in OPEN/WRITE statements? Or is this a compiler bug in IVF?
Thanks in advance.
Ben
program WriteMemoryLeak
integer :: ios
character(36) :: fil
integer, dimension(512) :: p
integer :: k, i
    fil='IntelWriteTest.dat'
    open( 8, file=fil(:len_trim(fil)), access='direct', form='unformatted', recl=kind( 1. )*512, status='unknown', buffered='NO', iostat=ios ) ! DEVWARN: PORTABILITY -- again, this may not be a Good Thing
    do m = 1, 200000
       p=m
       ! write( 8, rec=4+m-1, iostat=i ) p
       call writefile(m, p, 512)
    enddo
end program WriteMemoryLeak
subroutine writefile(k, p, n)
integer :: k, n
integer, dimension(n) :: p
integer :: i
       write( 8, rec=4+k-1, iostat=i ) p
end subroutine writefile
I tried your program with the 12.1 compiler and did not see any memory growth while the program ran - either for the process itself or for the system as a whole.  I will comment that your multiplying the RECL by KIND(1.) will make the file four times larger than it should be, since, by default, RECL= is in 4-byte units.  Either remove the multiply or compile with /assume:byterecl.  I would also comment that using KIND this way is very non-portable, since KIND numbers do not necessarily correspond to element size.  You could use the SIZEOF() intrinsic extension.  We support the F2008 C_SIZEOF function from ISO_C_BINDING in our next release coming soon.
If Windows is holding on to memory, there's not much we can do about it, but I don't see such an effect when I try it.
Ben_W_
Hi, Steve:
Thanks for your reply. I compiled my program with IVF 12.1.5.344 and saw the serious memory leak. It's very strange but good to hear that you do not have the memory leak. If possible could you please email me the whole solution file in a zip file? I think that some setting of the project is causing this memory leak. And I would like to try your solution file. My email address is pinnacleman98@gmail.com.
Another thought is that it could be Windows 7 that causes this problem. What operating system are you using?
BTW, we already noticed the portanbility issue on the kind(1.0). We kept it there for historic reason.
Ben
I did not use a solution - I just compiled your source from the command line, using 12.1.5.344 and Windows 7 and no switches. I saw no growth at all in process or memory use during the run of the program.
The KIND is not just portability - it will make your file 4 times bigger than it should be, unless you enabled the "byterecl" option.
Ben_W_
Hi, Steve:
Thanks. So what command do you use to compile my program? Can you post it here? If you did not see memory leak but we do, then there must be something different in using IVF, given same IVF version and wIndows 7. I would like first duplicate what you are doing on my machine and figure out what's wrong in my project settings.
We do enable the "byterecl" option in our project setting and the size of our output data file is correct.
Ben
Ben_W_
Hi, Steve:
I figured out how to use command line to compile my demo code. But again I still see the increase of the memory usage about 400M in the Performance Tab in the Windows Task Manager. I don't why.
Ben
I just used "ifort" with no options. Tried it again with /assume:byterecl and I see that the memory usage does go up a bit less than 400MB the first time I run it, but that's not what I'd call a leak as it just goes there and stays while the program is running.  If there was a leak I'd expect the memory usage to keep growing as the program runs.
When I run the program a second or third time, I don't see the system memory use increasing. I also note that Windows claims the process is using just a bit over 1MB, which definitely lets out anything in the compiler or run-time library.  I guess Windows is allocating some internal memory for the operations - don't really know.
John_Campbell
New Contributor II
Ben,
I tried and modified your example but did not see any memory leakage. I put a pause in your program, so I could see the process in the Processes tab of task Manager. It runs very quickly !
You might like some of the alternative OPEN I used.
[bash]program WriteMemoryLeak
  integer :: k, i, ios
    fil='Mem_Leak.log'
!    open ( 8, file=fil(:len_trim(fil)), access='direct', form='unformatted', recl=kind( 1. )*512,    &
!           status='unknown', buffered='NO', iostat=ios ) ! DEVWARN: PORTABILITY -- again, this may not be a Good Thing
    open ( unit     = 8,              &
           file     = fil,            &
           access   = 'direct',       &
           form     = 'unformatted',  &
           recl     = size(p),        &
           status   = 'unknown',      &
           buffered = 'NO',           &
           iostat   = ios )
    write (*,*) 'Opening ', trim(fil),' status =',ios
    do m = 1, 200000
       p = m
       call writefile (m, p, 512)
    end do
    write (*,*) 'end of test : to leave process live in Task Manager'
    read  (*,*) m
subroutine writefile (k, p, n)
  integer :: k, n
  integer :: i
    write ( 8, rec=4+k-1, iostat=i ) p
[/bash]
Ben_W_
Steven:
It seems that you finally saw what i meant for the 'memory leak'. I forgot to mention to you. If you run the program many times with very short interval time between each run, you only see one-time memory increase. But if you wait  long enough, may be couple of minutes,  after the previous run is finished (monitor the Performance Window to let the memory decrease to the level before the run), and you run the program again, you will see the memory leak again. In other words, if you run the program with very long interval time, you will see the memory leak every time you run the program.
Now I think that this problem is related to the file caching feature of the Windwos system. In C++, I can program the code to disable the file caching and flush the data directly into the binary file. But In Fortran, we do not have such control on the file caching. We have to reply on IVF compiler to provide us this capability on the OPEN/WRITE statements.
Ben
DavidWhite
Valued Contributor II
Can you periodically use the FLUSH statement to cause the data to be written from the cache to disk?
David
How do you do it in C++?  I will repeat that this is not a leak - it is simply using more memory than you would like.  A leak indicates memory allocated and then lost track of.
Ben_W_
Steve:
I agree that it is not a memory leak. But our customers reported it as memory leak because it is our software product that used up all their memory when they write out a few gigbyte of data.
Here is the link in Microsoft MSDN that discusses the file caching and how to disbale it http://msdn.microsoft.com/en-us/library/windows/desktop/aa364218%28v=vs.85%29.aspx. Basically when you open the file for access, you can set a flag to turn the file caching off for that particular file. I think that when Intel implemented the OPEN statement in IVF, you might ignore that feature. I hope that you can add this capability in as soon as possible if it has not been implemented. Right now, we are stuck with this "memory leak" problem.
Ben
Ben_W_
David:
I tried both FLUSH(8) and call FLUSH(8), both failed to solve the problem. So I don't know what is really causing this problem?
Ben
You can use a USEROPEN routine to set that flag for when the file is opened.  Look up USEROPEN in the documentation.
Ben_W_
Steve:
I tried USEROPEN as you suggested and set the FILE_FLAG_WRITE_THROUGH flag. I found that the problem is still there and the writing speed is much slow, which is expected as there is no caching anymore. But the strange thingg is the memory usage is still slowly increase as writing to the file continues. It seems that Windows is still caching the data. I'm really puzzled by this problem. Any new ideas on what's happening?
BTW, does any other customer report or notice this problem before?
Ben
I have not seen other reports of this problem.  In the tests I did, memory usage was steady throughout the program - indeed, I saw available pages actually go up a bit during the run.
John_Campbell
New Contributor II
This memory leakage is disk cacheing of file I/O. It has become much more noticeable with windows 7. I've only noticed a significant improvement in performance when the OS uses this approach. I do not know how to turn it off, or would I want to. Closing the file would flush the buffers and possibly reduce the buffering by the OS.
The OS is estimating that this memory is best used for this purpose.
John
Ben_W_
Hi, all:
Thanks you all for your kind replys. The problem is solved! The trick is to pass/set FILE_FLAG_NO_BUFFERING flag in the USEROPEN function. Note passing/setting FILE_FLAG_WRITE_THROUGH  flag does not work. I noticed that the writing speed is a little bit slower compared to normal writing, but not significant. I'm not concerned too much on the writing speeding, comparing the memory usage. Also I found  avery useful memory monitoring tool called RAMMAP.exe, which can be downlaoded from microsoft, http://technet.microsoft.com/en-us/sysinternals/ff700229.aspx. This tool shows all cached memory for each individual file plus a lot  of other information.
But now I'm having a calling convention problem in my real application. I think I can figure that out by myself. Here is the final working code that does not have te 'memory leak'.
    EXTERNAL UOPEN
        fil='WriteMemoryLeak.dat'
        recl_len = size(p)
        open ( unit     = 8,              &
               file     = fil,            &
               recl     = recl_len,        &
               buffered = 'NO',           &
               iostat   = ios, useropen=UOPEN )
        do m = 1, 200000
           p = m
        end do
        close(8)
      integer :: k, n
      integer :: i
      logical :: commit_result
    INTEGER FUNCTION UOPEN( FILENAME,      &
                           DESIRED_ACCESS, &
                           SHARE_MODE,     &
                           A_NULL,         &
                           CREATE_DISP,    &
                           FLAGS_ATTR,     &
                           B_NULL,         &
                           UNIT,           &
                           FLEN )
    !DEC$ ATTRIBUTES C, ALIAS:'_UOPEN' :: UOPEN
    !DEC$ ATTRIBUTES REFERENCE :: FILENAME
    !DEC$ ATTRIBUTES REFERENCE :: DESIRED_ACCESS
    !DEC$ ATTRIBUTES REFERENCE :: SHARE_MODE
    !DEC$ ATTRIBUTES REFERENCE :: CREATE_DISP
    !DEC$ ATTRIBUTES REFERENCE :: FLAGS_ATTR
    !DEC$ ATTRIBUTES REFERENCE :: UNIT
    USE IFWIN
    IMPLICIT INTEGER (A-Z)
    CHARACTER*(FLEN) FILENAME
    TYPE(T_SECURITY_ATTRIBUTES), POINTER :: NULL_SEC_ATTR
    ! Set the FILE_FLAG_WRITE_THROUGH bit in the flag attributes to CreateFile( )! (for whatever reason)
    ! FLAGS_ATTR = FLAGS_ATTR + FILE_FLAG_WRITE_THROUGH   ! does not work
    FLAGS_ATTR = FLAGS_ATTR + FILE_FLAG_NO_BUFFERING
    ! Do the CreateFile( ) call and return the status to the Fortran rtl
    STS = CreateFile( FILENAME,             &
                      DESIRED_ACCESS,       &
                      SHARE_MODE,           &
                      NULL_SEC_ATTR,        &
                      CREATE_DISP,          &
                      FLAGS_ATTR,           &
                      0 )
     UOPEN = STS
     RETURN
     END
John_Campbell
New Contributor II
I am surprised that you need to resort to this approach. I have done some testing of file I/O performance on XP, XP_64 and Win7_64, with HDD and SSD. My experience has been that Win 7 will utilise free memory much better (and take much more) than XP does. However I have not seen this cacheing adversely affecting other processes.
You might need to find out what hardware profile your user is comparing. Certainly more memory or using a SSD can significantly improve disk and then response performance.
My impression has been that Win7 does a much better job of buffering I/O. I would not expect turning this off is the best solution. This post should be about "Useful memory leak when writing to a binary file".
There must be more to your user's perceived problem.
John
SergeyKostrov
Hi Ben, I'm a little bit late since the problem is already solved... Congratulations!
Quoting intel@breault.com
...Thanks you all for your kind replys. The problem is solved! The trick is to pass/set FILE_FLAG_NO_BUFFERING flag in the USEROPEN function. Note passing/setting FILE_FLAG_WRITE_THROUGH  flag does not work. I noticed that the writing speed is a little bit slower compared to normal writing, but not significant...
This is absolutely expected and such tricks, like writing some huge amounts of data without caching, always affect performance.
I simply wanted to join a "Not-A-Memory-Leaks" group and your problem really didn't look like a memory leaks.
Please take a look at a screenshot and this is an example of a very fast memory leaks followed by an application crash and
then Windows released all allocated memory:
Sergey
You mentioned calling convention problems.  You must make sure that your USEROPEN routine uses the default (C) convention, and not STDCALL, even if the rest of the program uses STDCALL.  This applies to any kind of "callback" routine - the calling convention must match the expected default. (In the case of Windows API routines, of course, that's STDCALL.) For USEROPEN and IMSL passed functions, always use the ifort default convention.
