29282 Discussions
ServerCom failed to register with regsvr32
pellea
Visual Fortran Compiler XE 12.0.1.127 [IA-32]cannot register the DLL.
I have the following error in the output tab:
Registering output...
set PATH=C:\\Program Files\\Intel\\ComposerXE-2011\\\\redist\\ia32\\compiler;C:\\Program Files\\Intel\\ComposerXE-2011\\\\redist\\ia32\\mkl;%PATH%
cd /D A:\\Develop\\Sources\\Intel\\ServerCom\\Debug\\
regsvr32.exe /s "ServerCom.dll"
Project : error PRJ0019: A tool returned an error code from "Registering output..."
How can I resolve this?
Pellea
This error suggests that your DLL depends on another DLL that is not found or is the wrong version. Download Dependency Walker, run it and drag your DLL onto its window. See what errors it gives you. Ignore things such as IESHMS.DLL.
Try a "regsvr32 ServerCom.dll" from a Fortran Build Environment command prompt - what error do you get? You might also look at the build log to see if a more helpful error is there - the PRJ0019 error is generic and not helpful.
pellea
This is already the result of the HTML build log file.
When I executed this command I got a popup with this error:
"The module "ModuleName" was loaded but the call to DllRegisterServer failed with error code 0x80040201".
pellea
Great thanks.
There was well a missing DLL. We added it and it works!
