29386 Discussions
Setting location of Console & clearing contents?
rkaehler
Is there a programatic way to set the initial location of a console window created using AllocConsole() (or move it after creation)?
Also, is there a way to clear the console buffer?
TIA
anthonyrichards
New Contributor III
Quoting - rkaehler
TIA
Look in the language help index and you will find loads of Windows API console functions.
To move the console window, use SetConsoleWindowInfo to place the console window where you want it. It needs a console screen buffer handle as an argument.
To wipe the console window, create another console screen buffer using CreateConsoleScreenBuffer, save its handle.
Switch to the new (empty) buffer using SetConsoleActiveScreenBuffer.
Delete buffers that are no longer required using the CloseHandle function.
