Errors in linking C with Fortran
sarma_amras
Hi, I am facing these errors. Tried solving looking at other threads given in this forum and in other forums too.
But I couldn't resolve these. Please help in this regard.
C_files.lib(get_bvindx_info.obj) : warning LNK4075: ignoring '/EDITANDCONTINUE' due to '/INCREMENTAL:NO' specification
libifcore.lib(for_diags_intel.obj) : error LNK2019: unresolved external symbol __iob referenced in function _for__io_return
libifcore.lib(for_nt_open_proc.obj) : error LNK2001: unresolved external symbol __iob
libm.lib(libm_error.obj) : error LNK2001: unresolved external symbol __iob
libifcore.lib(for_rseq_nml.obj) : error LNK2019: unresolved external symbol __pctype referenced in function _for__nml_lex
libifcore.lib(for_io_util.obj) : error LNK2001: unresolved external symbol __pctype
libifcore.lib(tbk_traceback.obj) : error LNK2001: unresolved external symbol __pctype
libifcore.lib(for_rseq_nml.obj) : error LNK2019: unresolved external symbol ___mb_cur_max referenced in function _for__nml_lex
libifcore.lib(for_io_util.obj) : error LNK2001: unresolved external symbol ___mb_cur_max
libifcore.lib(tbk_traceback.obj) : error LNK2001: unresolved external symbol ___mb_cur_max
libifcore.lib(for_init.obj) : error LNK2019: unresolved external symbol __pxcptinfoptrs referenced in function _GETEXCEPTIONPTRSQQ
libifcore.lib(for_init.obj) : error LNK2019: unresolved external symbol ___argv referenced in function _for_rtl_init_
libifcore.lib(for_init.obj) : error LNK2019: unresolved external symbol ___argc referenced in function _for_rtl_init_
Debug/fortran_files.exe : fatal error LNK1120: 6 unresolved externals
I have tried maintaining that all sources are compiled with the same libraries option (/libs or one of the various /Mxx options). Still no lcuk.
Thanking you in advance
Kameswara Sarma
TimP
In th absence of sufficient information from you, it looks like you are mixing incompatible brands of Fortran, or you aren't compiling and linking with a single version of ifort, with the PATH variables set, as the ifortvars script would do.
sarma_amras
Quoting - tim18
I couldn't get you...
I have only one version of Fortran (IVF 11.0) and trying to integrate with the VS2005.
I have ensured that every matches in both C & Fortran. I am not sure of what else I need to do. Also not sure what more information you are needed to solve this.
