Setting upper and lower limits to integer variable values
warwickb1
I would like to create a Percentage Type variable that can only have integer values between 0 and 100.  I can't see a way of specifying such a type.  The only limits that I can see are those that can be applied is to dimensions, not values.  Am I missing something, please?
andrew_4619
You could make your percentage variables/types within a module and make use of public an private attributes. You could make some functions such that the percentage types are set / modified/ accessed via module functions that enforce some rules perhaps. Not knowing axactly what you are trying to do it is hard to be more specific.
DavidWhite
Valued Contributor II
This doesn't answer your question about creating a type that can only have the values 0 to 100, but you can force values between 0 and 100 by using
Value = Min(Max(Value,0),100)
David
andrew_4619
