We have a PC cluster including both Pentium4 and PentiumD machines.
However, the master node, where all compilations are done, is a PentiumD.
I have several quick questions:
1) For PentiumD, is the EM64T version of the Fortran compiler (i.e., the "fce" one) the right version I should use?
2) If I want to compile an executable on the PentiumD master node, which is
to be run on the Pentium4 nodes, can I still use the EM64T version?
Sun
Sun
You would use the IA-32 compiler unless you were running an "x64" version of Linux on the box. Since your cluster includes some IA-32 only systems, it would make more sense for you to use the IA-32 (fc) compiler throughout.
The Pentium D can run as either IA-32 or IA-32 with EM64T, depending on how you have configured it in the BIOS and which OS variant you boot.
