29277 Discussions
Severe problem: corrupted installation?
Arjen_Markus
in my examination of a problem with linking against a LAPACK library, I ran into a severe problem:
the installed compiler is not functioning anymore.
I can not be sure my actions are the real cause, so I will just report what happened:
I got runtime errors with a program linked against the LAPACK library I built from sources.
The message I got while linking it was:
LINK: warning LNK4098: defaultlib 'MSVCRT' conflicts with use of other libs; use /NODEFAULTLIB:library
So I tried it with a modified command:
ifort chklink.f lapack.lib blas.lib /nodefaultlib:MSVCRT.LIB
The compiler complained about the unknown option /nodefaultlib:, but it also produced some rather
unexpected messages:
Intel Visual Fortran Compiler Professional for applications running on IA-32, Version 11.1 Build 20100414 Package ID: w_cprof_p_11.1.065
Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
ifort: command line warning #10006: ignoring unknown option '/nodefaultlib:MSVCRT.LIB'
chklink.f(11): error #5149: Illegal character in statement label field
chklink.f(11): error #5149: Illegal character in statement label field [:]
chklink.f(11): error #5144: Invalid character_kind_parameter. No underscore
chklink.f(13): error #5149: Illegal character in statement label field
R6034
chklink.f(14): error #5149: Illegal character in statement label field
An application has made an attempt to load the C rntime library incorrectly.
chklink.f(11): error #5082: Syntax error, found 'DEFAULT' when expecting one of: ASSOCIATE DO FORALL SELECT WHERE IF SELECTCASE SELECTTYPE
chklink.f(15): error #5149: Illegal character in statement label field
Please contact the application's support team for more information.
chklink.f(17): error #5149: Illegal character in statement label field
The application failed to initialize properly (0xc0000142). Click on OK to terminate the application.
chklink.f(15): error #5120: Unterminated character constant
chklink.f(17): error #5144: Invalid character_kind_parameter. No underscore
chklink.f(15): error #5082: Syntax error, found CHARACTER_CONSTANT 's support team for more information.plication failed to initialize properly (0xc0000142). Click on OK ' when expecting one of: ( % : . = =>
chklink.f(17): error #5082: Syntax error, found END-OF-FILE when expecting one of: ;
compilation aborted for chklink.f (code 1)
I read the documentationas printed via ifort /help and saw that I needed to add /link in there.
I tried it. I got the same or almost the same set of error messages.
I even got this with:
ifort /c chklink.f
I rebooted the machine - I got the same messages!
I can only conclude that something has been corrupted on my machine, and my guess is it
has to do with the option /nodefaultlib: that I used incorrectly, but I can not be sure (and
I do not want to try it on another machine).
Arjen
mecej4
I have a suspicion that your have accidentally redirected the error messages from the compiler into what you think is a Fortran source file. Please type out the chklink.f file and see what it contains.
I think that E. Dijkstra's Rule-0 of programming can be helpful in situations such as this.
Arjen_Markus
Oh, you may be very right! I was stupidly using this source file for logging my actions as well - and never thought that text wouldget compiled too
Well, better me being stupid, than the installation being corrupted.
Arjen
