29648 Discussions
Shared library and DEC ALIAS issue with underscore
Jacob_Williams
New Contributor III
I'm using dlopen and dlsym to open a shared library and execute a procedure. It works fine on Windows and Linux, but I see a weird issue on Mac. Consider the following example:
Main code (main.f90):
program main
    use, intrinsic :: iso_c_binding
    implicit none
    procedure(func),pointer :: execute  !! procedure in the shared lib
    integer(c_intptr_t) :: dll_handle
    integer(c_intptr_t) :: procaddress
    integer(c_int),parameter :: rtld_lazy = 1
    abstract interface
        subroutine func(id)
        implicit none
        integer,intent(in) :: id
        end subroutine func
    end interface
    interface
        function dlopen(library, iflag) result(handle) bind(c, name='dlopen')
            import
            implicit none
            integer(c_intptr_t)                             :: handle
            character(kind=c_char),intent(in),dimension(*)  :: library
            integer(kind=c_int),intent(in),value            :: iflag
        end function dlopen
        function dlsym(handle, method) result(funptr) bind(c, name='dlsym')
            import
            implicit none
            integer(c_intptr_t)                             :: funptr
            integer(c_intptr_t),intent(in),value            :: handle
            character(kind=c_char),intent(in),dimension(*)  :: method
        end function dlsym
    end interface
    dll_handle = dlopen('test.so'//c_null_char, rtld_lazy)
    procaddress = dlsym(dll_handle, 'execute'//c_null_char)
    call c_f_procpointer(transfer(procaddress,c_null_funptr), execute)
    call execute(42)
end program main
Shared library code (test.f90):
module test_module
    implicit none
contains
    subroutine execute(id)
    ! -- DEC$ ATTRIBUTES ALIAS : "execute" :: execute ! doesn't work
    !DEC$ ATTRIBUTES ALIAS : "_execute" :: execute ! works
    write(*,*) '[execute] id = ', id
    end subroutine execute
end module test_module
Built using:
ifort -dynamiclib test.f90 -o test.so
ifort main.f90 -o main
I'm unable to access the procedure as "execute" without prepending an underscore to the DEC ALIAS command. This is not necessary on Windows or Linux. Is there some DEC magic that will allow me not to have to add this? Is this a bug in the Mac compiler?
Note that I think bind(c) also makes it work, but I can't use that for my real code since the procedure contains non-interoperable arguments.
FortranFan
You may want to look into DECORATE option with !DIR$ ATTRIBUTES and see if that provides a "portable" approach across the 3 platforms:
https://software.intel.com/en-us/fortran-compiler-developer-guide-and-reference-attributes-decorate
module test_module
    implicit none
contains
    !DIR$ ATTRIBUTES DECORATE :: execute ! Does this work?
Jacob_Williams
New Contributor III
Ah ha! DECORATE by itself doesn't work, but when I use both like this:
!DEC$ ATTRIBUTES DECORATE,ALIAS : "execute" :: execute
It does work (at least on Mac). Still need to check Windows and Linux. Thanks!
