Shift array index without copying
Wee_Beng_T_
I have an array e.g. A(3:7,4:8). So index starts from 3 / 4 and ends with 7 / 8. I would like to change it to A(43:47,44:48) without creating a new array and copying it. Is that possible? The array could be dynamically allocated ones. The values in the array will be changed so it doesn't matter if they are the same or not.
jimdempseyatthecove
program arrayindex
    implicit none
    real, target :: rawA(5,5)
    real, pointer :: A(:,:)
    integer :: r,c
    do r=1,5
        do c=1,5
            rawA(c,r) = c*10+r
        end do
    end do
    A(3:7,4:8) => rawA
    print *, A
    A(43:47,44:48) => rawA
    print *,A
end program arrayindex
Jim Dempsey
Wee_Beng_T_
Thanks Jim for the solution!
