I have a quickwin application to do some calculations. Up to now I show the resultsas numerical values in edit fields of the dialog where also the input data is entered. But now the results should be shown as graphs in a diagram. Which element can I use to show a diagram with an x-, y-axis and several curves (in different colors or with different line types)? Is that possible at all?
If that's not possible, what can I use alternatively? Is there an easy to use application which can be combined with visual fortran?
Thanks in advance
hpb
thank you for your quick answer.
I'm using CVF 6.1.0. Does that release also supports the mentioned librayr? And can you tell me please where I can get the example and the library?
Thanks in advance.
hpb
sorry, I found the example myself meanwhile. I will try it.
thanks hpb
