Signed zero issue
David_Billinghurst
New Contributor III
Is the following a bug?  Compiled with Fortran 2019u4 x64 under Windows 10 with /O:d.  I have read the Floating-point Optimizations section of the manual, but didn't find any mention of the treatment of minus zero.
With s=-1; y=s*0.0_8 we have IEEE_CLASS(y)==IEEE_POSITIVE_ZERO
program signed_zero_03
  use, intrinsic :: ieee_arithmetic
  implicit none
  integer s
  real(8) x,y
  s=-1
  x=0.0_8
  y = s * x
  write(*,*) (IEEE_CLASS(y)==IEEE_POSITIVE_ZERO)
  y = -1 * 0.0_8
  y = s * 0.0_8
end
with output
 F
 F
 T
Steve_Lionel
Not a bug. If you want to rely on the stranger parts of IEEE arithmetic, you have to compile with /fp:strict.
I modified the program as follows:
  implicit none
  integer s
  real(8) x,y
  s=-1
  x=0.0_8
  y = s * x
  write(*,101) (IEEE_CLASS(y)==IEEE_POSITIVE_ZERO), y
  101 format (L1, 1X, Z16.16)
  y = -1 * 0.0_8
  y = s * 0.0_8
  write(*,101) (IEEE_CLASS(y)==IEEE_POSITIVE_ZERO) , y
end
Compiling normally, I get:
F 8000000000000000
F 8000000000000000
T 0000000000000000
so you can see that the first two are negative zero, but the third is "positive zero".
But with /fp:strict:
F 8000000000000000
F 8000000000000000
F 8000000000000000
Now all three are negative zero. Without /fp:strict, the compiler is looser about such things and can give you arithmetically correct results that aren't what you get by strictly adhering to IEEE 754. Performance will be degraded in this mode.
Steve_Lionel
  implicit none
  integer s
  real(8) x,y
  s=-1
  x=0.0_8
  y = s * x
  y = -1 * 0.0_8
  y = s * 0.0_8
end
F 8000000000000000
F 8000000000000000
T 0000000000000000
F 8000000000000000
F 8000000000000000
F 8000000000000000
David_Billinghurst
New Contributor III
Thanks.  I hadn't cared about signed zeroes for a while and had forgotten which flags did what.
Steve_Lionel
FWIW, I once tried arguing with the developers that a USE of the IEEE modules ought to imply /fp:strict. I was unpersuasive at this.Chapter 17.1 (Exceptions and IEEE Arithmetic) spends a lot of text saying that if certain items from the modules are "accessible" then certain behaviors are in effect. For example:
The processor’s fullest support is provided when all of IEEE_FEATURES is accessed as in
   USE, INTRINSIC :: IEEE_ARITHMETIC; USE, INTRINSIC :: IEEE_FEATURES
but execution might then be slowed by the presence of a feature that is not needed.
Given the number of questions similar to yours that I received over the years, I thought such an implementation was appropriate and in the spirit if not the letter of the standard.
JohnNichols
Honored Contributor I
I have served on a IEEE Committee related to metric for many years, one sees the huge amount of free work these committee people do and they should be thanked, as applies to the many on this board who give generous time to answer many questions, some of which are actually difficult.
As noted by Dr Fortran - standards are a compromise, but so is life.  But my life is a lot richer for Fortran and the friendly people on this forum.
John
