29653 Discussions
Simple Fortran Question: Incrementing a FILE name within a loop
Michael_Cupples
I am looping on IHIST in the open statement below. I want to change the file name 'test100.txt' on the during looping such that I get a set of files at the end such as test101.txt, test102.txt, ..., test1000.txt
Pointing me to a known solution would be much appreciated. Note, I am new to character manipulation in FORTRAN, so do not understand how to formulate this problem
OPEN (UNIT=100+IHIST, FILE='test100.txt', STATUS='UNKNOWN')
Mike
DavidWhite
Valued Contributor II
WRITE(filename,'(a,i4.4,a)') "TEST",i,".TXT"
will enable you to create filenames from TEST0000.TXT to TEST9999.TXT
I'm not sure if you can specify UNIT=100+IHIST - hopefully someone else will answer that for you.
David
DavidWhite
David
mecej4
For the syntax of the OPEN statement, see section 9.4 of the Standard. You can see there that the unit number is allowed to be specified as a scalar integer expression.
If you must have files named test100.txt,... rather than test0100.txt, ...:
[fortran]character*12 :: filename
integer :: iunit
if(iunit.LT. 1000)then
   write(filename,'("TEST",I3,".TXT")')iunit
   open(unit=iunit+100,file=filename,status='unknown')
   close(unit=iunit)
else
   write(filename,'("TEST",I4,".TXT")')iunit
   close(unit=iunit)
endif   [/fortran]
Les_Neilson
Or just use the format I0 (that is zero)
Les
