Simple coarray test program generates segment faults
j0e
Hi All,
Just started playing with coarrays, and have this simple program
! This looks at a simple coarray version of doing a numerical gradient
   program CoarrayTest2
      implicit none
      real(8), allocatable:: cntl(:), grad(:)[:], gradF77(:)
      real(8) fcn
      integer n
  • character (len=10) junk if (this_image() == 1 ) then write(*,*) 'Number of images: ', num_images() write(*,'(a,$)') 'Enter size of vector: ' read(*,*) n end if sync all n = n[1] ! pass n to all images allocate ( cntl(n), grad(n)
  • , gradF77(n) ) cntl = 0. ! initialize vector call fcnAndGrad (n, cntl, fcn, grad) gradF77 = grad write(*,*) 'grad(', this_image(), ') = ', gradF77 stop end program CoarrayTest2 subroutine fcnAndGrad (n, cntl, fcn, grad) implicit none integer n ! it appears that you don't have to define n as coarray in subprogram if not using? real(8) cntl(n) real(8) fcn real(8) grad(n)
  • ! local declarations real(8) delA, fcnDel, aHold integer i, myImg, noImg myImg = this_image() noImg = num_images() call fcnValue (n, cntl, fcn) ! get the value of fcn for nominal a do i=myImg, n, noImg delA = real(i) aHold = cntl(i) cntl(i) = cntl(i) + delA ! perturb a vector element call fcnValue (n, cntl, fcnDel) grad(i)[1] = (fcnDel - fcn)/delA ! only modify grad on image 1 cntl(i) = aHold end do sync all ! wait for all images to finish grad = grad[1] ! broadcast completed gradient to all images return end subroutine fcnAndGrad subroutine fcnValue (n, cntl, fcn) implicit none integer n real(8) cntl(n), fcn fcn = sum(cntl)**2 return end subroutine fcnValue
  • This compiles and runs fine under Parallel Studio XE 2016 Update 2 under Windows, and it compiles fine under same version of PSXE for Linux, but when I run it (Centos 7, 3.10.0-229.4.2.el7.x86_64), it produces segment faults, suc as:
     Number of images:            8
    Enter size of vector: 1
    forrtl: severe (174): SIGSEGV, segmentation fault occurred
    In coarray image 1
    Image              PC                Routine            Line        Source
    a.out              0000000000480D85  Unknown               Unknown  Unknown
    a.out              000000000047E9A7  Unknown               Unknown  Unknown
    a.out              0000000000455354  Unknown               Unknown  Unknown
    a.out              0000000000455166  Unknown               Unknown  Unknown
    a.out              0000000000435276  Unknown               Unknown  Unknown
    a.out              00000000004051E0  Unknown               Unknown  Unknown
    libpthread.so.0    00007FE3F0099100  Unknown               Unknown  Unknown
    libicaf.so         00007FE3F05AC554  Unknown               Unknown  Unknown
    a.out              00000000004041D9  Unknown               Unknown  Unknown
    a.out              000000000040399E  Unknown               Unknown  Unknown
    libc.so.6          00007FE3EFCEAB15  Unknown               Unknown  Unknown
    a.out              00000000004038A9  Unknown               Unknown  Unknown
    application called MPI_Abort(comm=0x84000000, 3) - process 0
    Fatal error in MPI_Win_lock: Wrong synchronization of RMA calls , error stack:
    MPI_Win_lock(167)...: MPI_Win_lock(lock_type=235, rank=4, assert=0, win=0xa0000000) failed
    MPIDI_Win_lock(3068): Wrong synchronization of RMA calls
    forrtl: error (69): process interrupted (SIGINT)
    In coarray image 4
    a.out              0000000000405A2E  Unknown               Unknown  Unknown
    libpthread.so.0    00007FAD7567B100  Unknown               Unknown  Unknown
    libpthread.so.0    00007FAD756776D3  Unknown               Unknown  Unknown
    libmpi_mt.so.4     00007FAD74982585  Unknown               Unknown  Unknown
    libmpi_mt.so.4     00007FAD747DC7FB  Unknown               Unknown  Unknown
    libmpi_mt.so.4     00007FAD74800751  Unknown               Unknown  Unknown
    libmpi_mt.so.4     00007FAD74AA2316  Unknown               Unknown  Unknown
    libicaf.so         00007FAD75B91F45  Unknown               Unknown  Unknown
    libicaf.so         00007FAD75B8F0FB  Unknown               Unknown  Unknown
    a.out              000000000040429A  Unknown               Unknown  Unknown
    libc.so.6          00007FAD752CCB15  Unknown               Unknown  Unknown
    application called MPI_Abort(comm=0x84000000, 3) - process 3
    MPI_Win_lock(167)...: MPI_Win_lock(lock_type=235, rank=5, assert=0, win=0xa0000000) failed
    Completely trivial coarray programs do compile and run under the linux, just not the one above.  I suspect I have violated some coarray standard, but I can't see it yet, and I'm not sure why it runs fine under Windows 10 version of PSXE 2016.
    thanks!
    Lorri_M_Intel
    Per the standard, you must declare an interface for any procedure that has a coarray as a dummy argument.
    That did not happen here, and the compiler did not pass all the required "coarray-ness" from the caller to routine fncandgrad().
    It is probably not the argument named "N" that is the problem, because you are not accessing it as a coarray.   It is the one named GRAD, where you are actually accessing it as a coarray.
                     --Lorri
    Lorri_M_Intel
                     --Lorri
    j0e
    Excellent, Thanks Lorri!  I figured I was violating some standard.  Problem solved.
