29284 Discussions
Simple question but I am still confused!
wail
Hello everyone,
When I compiled my program no error encountered,but when I executed it
it gave this message
"forrtl: severe <24>: end-of-file during read, unit 11,file
D:myfilesinputs.dat"
I have tried to solve for this problem, for example:
1-I thought that my input file might have spaces that cause error when
reading the numbers.
2-Adding an error control statement such as"ERR=111"
open (11,file ='inputs.dat',status ='old',action ='read',ERR=111)
3- I have tried to use the(IOSTAT=) statement as the following
READ(11,*;IOSTAT=ierr) your_data
if(ierr==0) then
write(*,*) 'no error during read'
elseif(ierr<0) then
write(*,*) 'error : end of file'
elseif(ierr>0) then
write(*,*) 'other error'
endif
it showed no error in all "read" lines except the lines after
I could not solve this problem. May be becuase it is my first time to
write such a program.
Below is part of the program, hopefully someone might help.
Thanks to all
wael
program wael
implicit none
integer::i,j,nels,n,nn,s,iel,NEQ,k,kk,t,mm,mmm,tt,count1,count2
integer::iph,ilo,yy,vv,Nphi,Nload,Ndispx,idisp,rr,count11,count22
real::EI,L,power
!------------------------------dynamic
arrays----------------------------------
real,allocatable::phi(:),length(:),km(:,:),phi1(:,:),load(:)
real,allocatable::dtheta1(:),dtheta(:),lmoment(:),mom(:),dispx(:)
integer,allocatable::pre(:)
!------------------------input and
initialisation------------------------------
open (12,file ='solution.dat',status ='replace',action='write')
! 1-Reading number of elements and EI
read(11,*)nels,EI !
nn=nels+1
s=((nels*2)-1)+3
NEQ=s
allocate (phi(nn), length(nels),km(s,s),phi1(nels,nn),load(nn))
allocate (dtheta1(s),pre(s),dispx(nn),mom(nn))
allocate (dtheta(s),lmoment(s))
! Initializing Vectors and Arrays
do k=1,s
do kk=1,s
km(k,kk)=0.0
end do
end do
do t=1,s
dtheta(t)=0.0
dtheta1(t)=0.0
end do
do i=1,nn
phi(i)=0.0
load(i)=0.0
dispx(i)=0.0
pre(i)=0.0
mom(i)=0.0
end do
! 2-Reading Variables provided if any
read (11,*) NPhi,Nload,Ndispx
if (Nphi/=0) GOTO 100
100 read (11,*) (iph,phi(iph),yy=1,NPhi)
if (Nload/=0)GOTO 200
200 read (11,*) (ilo,load(ilo),vv=1,Nload)
if (Ndispx/=0)GOTO 300
300 read (11,*) (idisp,dispx(idisp),rr=1,Ndispx)
read (11,*) (length(j),j=1,nels)
count1=1
count2=1
do i=1,s
mm=MOD(i,2)
if(mm/=0)then
dtheta1(i)=dispx(count1)
count1=count1+1
pre(i)=1
else
dtheta1(i)=phi(count2)
count2=cou nt2+1
pre(i)=1
endif
end do
! Matrix
elements_1: do iel=1,nels
n=(iel*2)-1
length(iel)=L
power=L**3
km(n,n)=km(n,n)+12*EI/power
km(n,n+1)=km(n,n+1)+6*EI*L/power
km(n,n+2)=km(n,n+2)-12*EI/power
km(n,n+3)=km(n,n+3)+6*EI*L/power
km(n+1,n)=km(n+1,n)+6*EI*L/power
km(n+1,n+1)=km(n+1,n+1)+((4*EI*L**2)/power)
km(n+1,n+2)=km(n+1,n+2)-6*EI*L/power
km(n+1,n+3)=km(n+1,n+3)+((2*EI*L**2)/power)
km(n+2,n)=km(n+2,n)-12*EI/power
km(n+2,n+1)=km(n+2,n+1)-6*EI*L/power
km(n+2,n+2)=km(n+2,n+2)+12*EI/power
km(n+2,n+3)=km(n+2,n+3)-6*EI*L/power
km(n+3,n)=km(n+3,n)+6*EI*L/power
km(n+3,n+1)=km(n+3,n+1)+((2*EI*L**2)/power)
km(n+3,n+2)=km(n+3,n+2)-6*EI*L/power
km(n+3,n+3)=km(n+3,n+3)+((4*EI*L**2)/power)
end do elements_1
call gauss(NEQ,load,km,pre,dtheta1)
call BAKSUB(NEQ,load,km,pre,dtheta1,dtheta,lmoment)
! outputs
count11=1
count22=1
do i=1,s
mmm=MOD(i,2)
if (mmm/=0) then
load(count11)=lmoment(i)
phi(count11)=dtheta(i)
count11=count11+1
else
mom(count22)=lmoment(i)
dispx(count22)=dtheta(i)
count22=count22+1
endif
end do
! Printing the Node,Displacement,Phi,Moment and Shear
results: do i=1,nn
write (12,1000)i,dispx(i),phi(i),mom(i),load(i)
1000 Format (4x,i5,4x,e12.4,4x,e12.4,4x,e12.4,4x,e12.4)
end do results
111 end program wael
Intel_C_Intel
Maybe you need to add an error control statement such as"END=111"
Often you need an "ERR=111" AND "END=111"
David
Intel_C_Intel
Wael,
The problem appears to be that there is less data in your input file than your program is asking for. This can only be solved by looking at both the program and the data file.
The "ERR=" statement on the OPEN will only trap errors on the OPEN itself, not on any subsequent read. Adding an "IOSTAT=" qualifier to a READ should stop the system aborting the program execution; a "END=" qualifier should not also be _necessary_ .
I suggest that you either 1) examine the program together with the data file and e.g. count data items or 2) use the debugger to examine the data as it is read in, to see where it goes wrong.
Hope this helps,
Joe
