Dear all,
the 15.0.1 ifort compiler produces errors on the following snippets. Are these errors still present in 15.0.2 ?
If someone can give advice, this would help me to decide whether I have to check / change all such "sourced allocation assignments" or just wait for our IT to upgrade the compiler.
Snippet 1:
- Sourced allocation into polymorphic array
- Source is allocated function result
program p implicit none type :: t logical :: is_not_empty ! seg. fault without end type class(t), dimension(:), allocatable :: a allocate(a, source=make_alloc()) print *, allocated(a) ! T print *, size(a) ! 0 (wrong) contains function make_alloc() result(a) type(t), dimension(:), allocatable :: a allocate(a(5)) print *, size(a) ! 5 end function end program
Snippet 2:
- Derived type t has polymorphic component
- Sourced allocation into array of type(t) fails
program p implicit none type :: s logical :: is_not_empty end type type :: t ! CLASS is the problem here class(s), allocatable :: polymorphic_component end type type(t), dimension(:), allocatable :: a allocate(a, source=make_alloc()) print *, allocated(a) ! T print *, size(a) ! 0 (wrong) contains function make_alloc() result(a) type(t), dimension(:), allocatable :: a allocate(a(1)) end function end program
Snippet 3:
- Similar to snippet 2 but errorneous code is executed in subroutine
- Runtime-error (different, though probably related to snippet 2)
module m type :: s logical :: is_not_empty end type type :: t class(s), allocatable :: polymorphic_component end type contains subroutine main() implicit none type(t), dimension(:), allocatable :: a allocate(a, source=make_alloc()) print *, allocated(a) ! T print *, size(a) ! 0 (wrong) end subroutine function make_alloc() result(a) type(t), dimension(:), allocatable :: a allocate(a(1)) end function end module program p use m implicit none call main() ! forrtl: severe (153): allocatable array or pointer is not allocated end program
An other question to Intel: On the new free-software page, for students / researchers (=me) non-commercial licenses are not offered for Fortran any more. How can I test features and report bugs in the latest compiler? (here, IT departments usually don't have the very latest version, for stability and maintainance reasons)
Ferdinand
I can still reproduce these problems in 15.0.2 and will report them to the developers. Issue ID is DPD200367894.
You can continue to report issues here - if they are fixed in newer versions, we will let you know.
There is a limited return of non-commercial licenses - see https://software.intel.com/en-us/qualify-for-free-software - but Fortran is not currently included in the research or student offerings. This program is still evolving.
PS: I just noticed that the size is not specified in the allocation statements. In F2003-syntax, e.g. allocate(a(SIZE), source=...), the correct size will be printed in all snipptes, but accessing the array elements afterwards (even after correct initialization) fails with segmentation fault. Snippet 3 fails after correction with seg, fault even without any other changes.
By the way, according to the F2008 standard you don't have to specify the bounds for a in the ALLOCATE as they are taken from the source. F2003 still requires that the bounds be given and that the source be "conformable" with the object.
Thank you for the valuable information and the bug report, Steve!
For now I will allocate with intent(out) in subroutines rather than allocatable function results.
This turned out to be a simple bug when the source expression was a function result. I expect the fix to appear in Update 3 (May). Thanks for the nice test cases.
