Stack Overflow Bug when compiled with OpenMP?
Ulrich_M_
The following code compiles but crashes with a stack overflow on entry in the parallel region when compiled with OpenMP. I played with stack settings, but to no avail. Removing the block construct leads to expected results, as do other trivial changes to the program.
module compute
    implicit none
    integer             :: nth, ny
    integer, parameter  :: nsim=20
    real, allocatable   :: Ys(:,:)
    contains
    subroutine prep
        integer :: l
        real    :: Y(ny),th(nth)
!$omp parallel do private(Y)
        do l=1,nsim
            y=0
        enddo
        print *,"done"
        block
            do l=1,10
                Y=5
                th=0
            enddo
        end block
    end subroutine
end module
program mfort
    use compute
    implicit none
    nth=5; ny=8;
    allocate(Ys(ny,nsim))
    print *,"hello"
    call prep
end program
Devorah_H_Intel
The code builds and runs OK with 17.0.4 compiler.
