Stack problems with RESHAPE
sschneid
i tried to write a simple fortran routine that reads a binary file and stores the values in a two-dimensional array. The routine reads the data in a one-dimensional array and afterwards the RESHAPE function rearrange the data. My problem is, that i get some problems with the stack memory. Both arrays are allocated in the heap memory, i dont know if the RESHAPE function generates a temporary array in the stack.
I increased the stack memory in the c++ project settings to solve the problem. Is there a better solution for such a problem?
Thanks, Stephan
Yes, RESHAPE often creates a temporary copy on the stack. Increasing the stack size is the only option for now. We know that we have to add the ability to allocate temps on the heap.
sschneid
Thanks for the quick reply,
Stephan
