Before requesting text-based data entry I set the text & graphics foreground colour to code 15 (default: white), and the background to 0 (default: black).
On the first pass the user text is visible.
AFter I then plot a graph, and return to the text menu, the prompts are displayed, but the user text is no longer displayed - it appears to be black text on black, as the keystokes are correctly recognised.
What do I have to do to get the display to correct for text?
Perhaps a small test case would help us help you.
Is this acceptable?
Compile as standard graphics.
Run. Take [ENTER] to get past the help screen request.
Enter 9 to run the one option. (Any other key will exit).
Try entering 90, 90, [Enter].
[Enter] to get past the text-based graphics; [Enter] at the QuickWin graphic.
No to adding confidence intervals.
You should then be back to the submenu for option 9, where your keyed-in text is not visible. If you select 0 to return to the main index you again have your user text invisible at the main menu.
Missing QQQQDEMO.FOR.
Sorry.
The file has the following:
C
C QQQQDEMO.FOR Include file...
C ============
WRITE(6,500)
500 FORMAT(///
+ ' | Would you like ZEBRA to show you a |'/
+ ' | typical application of this module? |'/
+ ' Type "Y" for the demo, or'/
+ ' just press ENTER to skip it... ')
READ 501, ANS
501 FORMAT(A1)
IF(ANS.EQ.'Y' .OR. ANS.EQ.'y') THEN
Demo = .TRUE.
WRITE(6,502)
502 FORMAT(/' OK: each time you''re asked for an input,'/
+ ' just press ENTER and ZEBRA will supply a '/
+ ' typical value for you...'/)
END IF
C
C=================================================================
C
and may be replaced, I think, by a blank file, as long as you never request the 'Novice' option.
C
C ============
WRITE(6,500)
500 FORMAT(///
READ 501, ANS
501 FORMAT(A1)
Demo = .TRUE.
WRITE(6,502)
END IF
C
C
The file is required because there are references to the format labels.
I can reproduce this in version 12.0.4, but not in a future update. My guess is that you've run into the QuickWin bug people were reporting on Win7 that we have fixed. If you want a fixed library, submit a request to Intel Premier Support and ask that it be assigned to me. This fix is for version 12 only and I tested that the problem does not occur with the new library.
Also, I find that when built as Standard Graphics, the OPEN of unit 6 as USER fails with an error - not entirely sure why. If I remove that OPEN, which is not necessary, the program runs.
The OPEN to unit 6 ran fine with me - version 9 (!) of the compiler; and without it I had a problem, but that may have been while I was working with appropriate project settings to get graphics displayed.
For now I will leave it as documented as a bug with the compiler, while I see if I can get money to upgrade from Version 9.
Thank you for looking at this.
Short term rebuilt in Compaq Visual Fortran 6.1A, as this displays the text correctly. I have flagged up that we need to get permission to upgrade our copy of the Intel compiler.
![](/skins/images/76FBCD0056552B7B74FE0D35ED948B09/responsive_peak/images/icon_anonymous_message.png)
Topic Options
