29648 Discussions
Starting Array Counter from 'ZERO' from .NET environment
ftakh
Dear All:
I am using Intel Fortran V.8 from within .Net. From this environment, is there a way to make all the array counter starting from 'zero' instead of 'one' (e.g. by setting some option checked from the .Net GUI)?
-Arun
No. You have to declare the array with a zero lower bound. You're basically asking for a "pretend this isn't Fortran" switch!
g_f_thomas
That's good: a "pretend this isn't Fortran" switch. Where's the 'row-major order switch'?
Interesting to note that in deference to its Fortran lineage, Matlab's arrays are 1-based and of column-major order.
Ciao,
Gerry T.
Yeah, and the "run twenty percent slower" switch... :-)
That said, I am glad that we pushed the "creeping C" illness back under the covers by requiring a switch to recognize backslash as an escape introducer in string literals.
