29643 Discussions
Starting console application from Website
kai_larsen
Hi!
I'm trying to find the solution to the following problem: I have a console application that I want to link to from a Web Page, but any time I try to run it, it stops abruptly. It turns out that the application is looking for the external files (parameter file, etc.) in a VS directory rather than the directory where the console application resides.
Any suggestions for how to avoid this?
Thanks so much!
-- Kai :-)
Can you explain in more detail what you want to do? If you simply have an EXE that is a link on a web page, the web browser will download the EXE and run it from a temp folder.
When you are running inside Visual Studio, the default directory for files is the project directory.
kai_larsen
My desire is to invoke the fortran console application from a Website in such a way that the console application runs on the server until it is finished. There is no interactivity between the console application and the Website other than that the user can load a status file written by the console application as it continues to run.
What you say about the exe being copied to a temp folder makes sense as the system stops when it does not find the input files that it expects to find in the folder it was in before being copied to a temp directory.
Any and all ideas about how to solve this would be greatly appreciated!
Jugoslav_Dujic
Valued Contributor II
As far as I know, it's doable, but you need a CGI or similar gateway on the server side. It's really not my area of expertise, but check the archives of comp.lang.fortran about the topic; here's another hint. Oh, here's something even more useful:
http://www.ruppweb.org/Xray/comp/cgi_prog.htm
garylscott1
You may also need to ensure that appropriate permissions are set to allow execution of such programs. In some environments, these are considered security risks and are disallowed (even with execute priviledges set, the server setup prevents execution externally).
