29651 Discussions
Static structure (type) placed into common block
Ilgis_I_
I am porting legacy code that have
      structure aaa
      integer a1
      real      a2
C    ...
      end structure
      structure /aaa/ bbb(100)
      common /ccc/ bbb
so an array bbb of structures aaa is placed into a common block ccc and wish this portable across Win/UX main fortran compilers.
I used
      type aaa
      integer a1
      real a2
C     ...
      end type
      type (aaa) bbb(100)
      common /ccc/ bbb
      save /ccc/
however I cannot compile common and save statements on this code. Please, advice how to place said array of structures into common block and be sure that it is statically allocated and remain in memory?
Thank you!
Lorri_M_Intel
what errors are you seeing?    This compiled for me on Windows.
By the way, the SAVE is redundant; COMMON is already SAVE by definition.
                 --Lorri
andrew_4619
A common  block automatically has "save" status I do not think your SAVE is valid Fortran. If you are modernising why not share the data using a module rather than a common block.
Steve_Lionel
The SAVE of a common block is perfectly standard, though as noted, unnecessary. In some earlier Fortran standards you might have needed it if there were no active procedures that declared that common.
