Still having compiler problem
Anne_Stewart
I am still getting this error:
fortcom: Fatal: There has been an internal compiler error (C0000005)
when trying to compile legacy code on the 11.0.074 compiler. I'm attaching all the source code (zipped). Hope you can help. Thanks.
It's further down on that page.
I can reproduce the problem. Workaround: Project > Properties > Fortran > Diagnostics. Set Check Routine Interfaces to No.
The upcoming 11.1 (late June) also appears fine, even with Check Routine Interfaces on.
Anne_Stewart
This is great news. However, I can't find a check routine interfaces in the diagnostics. I set generate interface blocks to "no", that is the only mention of interfaces in the diagnostics window. The code will still not compile with this change, however.
Anne_Stewart
Hi Steve,
First, thanks for your rapid responses. Following your first reply yesterday, I changed some flags in diagnostics and anywhere else that looked promising, and rebuilt, and the code is finally compiling. You Intel folkshave beensuperb with your help in getting thisworking, and I really appreciate it. I am still pretty new at Fortran andcompletely new tothe Intel versionand your support pages here, and apologize for anyunnecessary run-around I've inadvertently given you folks.
FYI My diagnostics window does not havethe multiple options in your reply. It has only one option, if Iapply the +: Compile Time Diagnostics, which I selected as show all/warn all. I am running on VS2005, which may account for the difference.
Cheers!
Anne
Hmm - might be a compiler version difference. Check under External Routines to see if it shows up there.
You haven't given us any "run-around", and we apologize for the compiler bugs getting in your way.
Anne_Stewart
The rest of the diagnostic optionstoggleas I switch the setting in the configuration pull down menu from debug torelease - this is only happening in files with the troublesome code though. Also, I think Ifirst changed the configuration in the solution configurations window in the top toolbar.Anyway, I see by adjusting the configuration settings how to get tothose options in the future.
I've been able to compile the code several times now, and theexecutableisworking (with no more problems thanusual) so I think I'm in the clear.
Thanks for all the help!
Anne
