ifort > f77
hana008
I have a FORTRAN program, which used to run with ifort compiler. Because I am on another machine, I have to transfer it to f77.
I have a problem with options I shloud use>
the original setting is : ifort -04 -Bstatic -dn file
Can you help me transfer this command to f77?
Thank you
Hanka
Exactly which compiler is "f77"? It is very likely that your Fortran code will not be recognized by a Fortran 77 compiler.
ifort does not have an -O4 level. It does have -O3. However, optimization levels are not directly comparable across different compilers, so you'll have to look at the documentation for the other compiler to see what is appropriate.
-Bstatic affects linking and says to link with static libraries.
I don't recognize -dn
rreis
Sun fits the description...
http://www.atnf.csiro.au/computing/software/sol2docs/mr/READMEs/fortran_77.html
  • Linking on SPARC V9 Platforms Under Solaris 7 and 8:
  • Many static system libraries, such as libm.a and libc.a, are not available in Solaris 7 or 8 environments on SPARC V9 platforms. Only dynamic, shared libraries, libm.so and libc.so, are provided. This means that -Bstatic and -dn compiler options may cause linking errors on SPARC V9 platforms with Solaris 7 or 8. Applications must use dynamic libraries in these cases.
    To explicitly link with a static version of a user library while linking dynamically system libraries, use a command line that looks something like:
    f77 -o prog prog.f -Bstatic -lxyz -labc -Bdynamic
    This will link with libxyz.a and libabc.a, but all other libraries, including system libraries, will be linked dynamically.
    So it seems that the command line given was for "f77" and not ifort?
    hana008
    the line was given for ifort ... I have looked also, to manual and I also could not find -dn and -O4 .... but I knew it had worked for ifort.
    The problem were libraries, with which libraries I should link it? ...
    I suggest you ask whoever supports the "f77" compiler you are using.
    rreis
    maybe you could do f77 --version or f77 --help and find out which f77 compiler you have...
