Strange behavior of allocatable array with internal procedure
Wolf_W_
Greetings,
i got a problem with an allocatable array, that gets resized in an subroutine. Without the internal function "testArguments", the array has the expected size of 40 at the end. If "testArguments" is defined (no matter if it is called), the array stays the same size in the main program. "array" seems to become a local variable to "testArguments", instead of a reference to "foo_array".
It it doesn't matter if "testArguments" is a function or subroutine.
It works (any of those points):
- when the array is passed as argument to "testArguments".
- compiler-option /C is used
- optimizations are turned off (/Od)
- "array" is not used in "testArguments"
- "STRANGE_BLOCK" is present
This happens with compilers 15.5 and 16.1 (32bit and 64bit) on windows.
module TEST_MOD
  implicit none
contains
  subroutine foo
    integer, allocatable :: foo_array(:)
    allocate(foo_array(10))
    call extendArray(foo_array)
    ! It works, if this block exists
!    STRANGE_BLOCK : block
!      write(*,*)size(foo_array)
!    end block STRANGE_BLOCK
    write(*,*) 'Expected:'
    write(*,*) 40
    write(*,*) 'Got:'
    write(*,*) size(foo_array, dim=1)
  end subroutine
  subroutine extendArray(array)
    integer, allocatable, intent(inout) :: array(:)
    integer :: n
    ! Doesn't matter if called or not.
!    if(.NOT. testArguments()) return
    n = size(array,dim=1)+10
    deallocate(array)
    allocate(array(n))
    write(*,*) size(array,dim=1)
    contains! -------------------------------------------------------------
      ! does not work:
      logical function testArguments() result(valid)
        valid = allocated(array)
      end function testArguments
      ! works: (independent of used arg-name)
!      logical function testArguments(array) result(valid)
!        integer, allocatable, intent(inout) :: array(:)
!        valid = allocated(array)
!      end function testArguments
  end subroutine extendArray
end module TEST_MOD
program main
  use TEST_MOD
  call foo()
end program
Wolf
mecej4
Please see if turning off optimization (using option /Od) makes the bug go away (as it seems to on Linux).
Wolf_W_
yes, it goes away with /Od (as stated in original post - i should have been more specific)
mecej4
My lapse, I overlooked that line.
It is typical of optimizer bugs that they can be made dormant by any number of slight changes to the code, and can even be Heisenbugs. Thus, when those changes are described in detail, one tends to be side-tracked into analyzing those changes as to their specifics.
Wolf_W_
Thanks for introducing me to the term "Heisenbug" - i like that.
It actually confused me a lot, as it went away, when i wrote out the array in the block-part. I tried turning off the optimization only when i worked on the reproducer.
Steven_L_Intel1
Thanks, we'll take a look.
Steven_L_Intel1
Thanks for the nice test case and the observations. This has been escalated to the developers as issue DPD200380881. I will update this thread when I have news.
Steven_L_Intel1
This problem has been fixed. I expect the fix to appear in the 16.0.4 update as well as the 17.0 product release.
