29647 Discussions
Strange behavior with pointers in derived types when using OpenMP
luismsfern
Hello everyone,
I am having trouble identifying a problem that only shows up in my code when compiled with ifort (with gfortran code runs fine). In doing so, I created a small reproducible that mimics the derived types I am using in the code. Although the small reproducible does not exhibit the same error as my larger code, it does show some unexpected behavior that could point to the root of the problem, so I would like to understand what is happening. I am posting the code below:
module my_subroutines
  use, intrinsic :: iso_fortran_env
  implicit none
  type array_int32
    integer(kind=int32), dimension(:), allocatable :: arr
  end type array_int32
  type array_int32_ptr
    type(array_int32), pointer :: p => NULL()
  end type array_int32_ptr
contains
  subroutine print_rows(tid, row_ptr)
    implicit none
    integer(int32), intent(in) :: tid
    type(array_int32_ptr), dimension(2), target, intent(inout) :: row_ptr
    integer(kind=int32), pointer :: index => NULL()
    integer(kind=int32) :: i, j
    j = 1
    row_ptr(j)%p%arr(1) = 1000
    index => row_ptr(j)%p%arr(1)
    write(*,'(2(A,I0))') ' - row_ptr(1)p%arr(1) on thread ', tid, ': ', index
    j = 2
    write(*,'(2(A,I0))') ' - row_ptr(2)p%arr(1) on thread ', tid, ': ', index
  end subroutine print_rows
end module my_subroutines
program test
  use my_subroutines
  use omp_lib
  implicit none
  type(array_int32_ptr), dimension(2) :: row_ptr
  type(array_int32), dimension(2), target :: row
  integer(kind=int32) :: i, tid
  !$omp parallel default(none) &
  !$omp private(i, tid, row, row_ptr)
  tid = omp_get_thread_num()
  allocate(row(1)%arr(10))
  allocate(row(2)%arr(20))
  row(1)%arr = (/ (i, i=1,size(row(1)%arr) )/)
  row(2)%arr = (/ (i, i=1,size(row(2)%arr) )/)
  row_ptr(1)%p => row(1)
  row_ptr(2)%p => row(2)
  call print_rows(tid, row_ptr)
  row_ptr(1)%p => row(2)
  row_ptr(2)%p => row(1)
  deallocate(row(1)%arr, row(2)%arr)
  !$omp end parallel
end program test
and here is an example output running on 3 threads(which is *not* deterministic, pointing to some memory leak within the code):
 - row_ptr(1)p%arr(1) on thread 0: 1000
 - row_ptr(1)p%arr(1) on thread 1: 1000
 - row_ptr(2)p%arr(1) on thread 1: 1000
 - row_ptr(1)p%arr(1) on thread 2: 1987284000
 - row_ptr(2)p%arr(1) on thread 2: 1000
 - row_ptr(1)p%arr(1) on thread 2: 1000
 - row_ptr(2)p%arr(1) on thread 0: 2121468960
 - row_ptr(2)p%arr(1) on thread 0: 1000
I would expect the print out of the code to be 1000 for all threads. However, it seems that only the first thread that runs the print_rows subroutine behaves as expected, while the remaining ones seem to have garbage data.
In the context of my larger code, this behavior only shows up when the OpenMP section is present. If I comment out the OpenMP section from my code, it runs as expected, so it seems to be some interaction with the OpenMP library.
Any help identifying the source of this behavior would be greatly appreciated.
