Strange error with a simple DLL
Arjen_Markus
I have run into a strange error while experimenting with a DLL. The program works fine
when compiled gfortran (the experiment fails, but that is another matter), but it crashes
when compiled with Intel Fortran 11.1. At start-up it produces a messagebox with an
error message R6034 - the C runtime library was apparently wrongly loaded.
Here is the code for the main program:
program exchange1
use datadll
implicit none
integer :: value
character(len=1) :: dummy
value = 123
write(*,*) 'Exchange 1: Setting item to ', value
write(*,*) 'Press ENTER'
read(*,'(a)') dummy
call putitem( value )
write(*,*) 'Exchange 1: Set item to ', value
write(*,*) 'Press ENTER when ready'
read(*,'(a)') dummy
end program exchange1
And this is the code for the DLL:
! datadll.f90 --
! Define a module with data - the module is part of a DLL
module datadll
implicit none
real, dimension(10) :: array
!dec$ attributes dllexport:: array
integer :: item
!xxdec$ attributes dllexport:: item
contains
subroutine initdata
!dec$ attributes dllexport:: initdata
call random_number( array )
end subroutine initdata
subroutine putitem( value )
!dec$ attributes dllexport:: putitem
integer :: value
item = value
end subroutine putitem
subroutine getitem( value )
!dec$ attributes dllexport:: getitem
integer :: value
value = item
end subroutine getitem
end module datadll
Here is the batchfile I use to compile it:
ifort -dll datadll.f90
ifort exchange1.f90 datadll.lib
The funny thing is, if I call the subroutine initdata (this is in another test program) it works
fine. I do not see what the difference is between the two and why the _presence_ of a call to
putitem should crash the program at start-up (it happens before any statement is executed!)
Can anyone solve this puzzle?
Arjen
mecej4
Check your IVF installation. With IVF11.1.065, I get no errors/crashes
[bash]S:LANG>Exchange1
 Exchange 1: Setting item to          123
 Press ENTER
 Exchange 1: Set item to          123
 Press ENTER when ready[/bash]
Have you placed copies of any Microsoft Visual C++ DLLs in the problem program's folder?
Arjen_Markus
mecej4, Steve,
the directory contains no DLLs from MicroSoft Visual C++.
The odd thing is that the following program that uses _the same_ DLL in the same directory
has no problem at all:
! getdatadll.f90 --
! Get data from a DLL
program getdatadll
use datadll
implicit none
call initdata
write(*,*) array
end program getdatadll
Note: I run the compiler in a DOS-box via the Start menu option "Fortran Build Environment for applications on IA-32"
The compiler works fine for several large programs I build on the same machine.
Arjen
Arjen_Markus
Actually, it gets worse:
! getdatadll.f90 --
program getdatadll
use datadll
implicit none
integer :: value
call initdata
write(*,*) array
value = 11
value = 12
call getitem( value )
write(*,*) value
(so with calls to the routines that cause the trouble in the other program) runs fine.
Even if I leave out the call to initdata and the first write statement it works fine.
The exchange1 program I posted still gives this nasty trouble.
Arjen
Download Dependency Walker, run it and drag your EXE onto the window. From the File menu, select Save As to save a .dwi file. Attach the .dwi file to a reply here.
Arjen_Markus
Yesterday, I had a chance to test the set-up on a completely independent installation (I was presenting
the course I wrote the original program for). It turned out that:
- Compiling the DLL and the programs in a DOS-box set up for Intel Fortran I got the same problems
- Compiling the DLL via MS Developer Studio and then _copying_ the previous executables into the
Debug directory made the programs work without a fuss.
I sent the DWI-file to Steve directly, but Dependency Walker only complained about a DWMAPI.DLL it could
not find. There was no discernible difference between the reports for the program that does work and the
program that does not. Well, I remain puzzled ;)
Arjen
