Strange memory issue
Tobias
Dear Intel forum users:
I've stumbled upon a very *strange* issue (don't know how else to describe it) where with certain optimizations an array gets filled with bogus data.
I have tried to produce a minimal example, but in the end the example is still pretty large because it only happens under quite specific circumstances. The issue does not occur with "-O1" or less, or with "-O2" and without openmp. The (unused!) threadprivate variable is important. It is also important that the module is in a separate file. It also matters that ndim is not hardcoded but passed as a variable.
testcase.f90:
program main
      use test
      implicit none
      double precision :: msq(10,-5:5,-5:5,5,2)
      msq = 0d0
      call fillmsq(10, msq)
end program
test.f90:
module test
      implicit none
      public
      contains
      subroutine fillmsq(ndim, msq)
          implicit none
          integer, save :: blub
!$omp threadprivate(blub)
          integer, intent(in) :: ndim
          double precision, intent(inout) :: msq(ndim,-5:5,-5:5,5,2)
          integer :: j,k,l,m,n
          do j=1,ndim; do k=-5,5; do l=-5,5; do m=1,5; do n=1,2
              if (msq(j,k,l,m,n) /= 0d0) then
                  write (*,*) "BEFORE", j,k,l,m,n, msq(j,k,l,m,n)
              endif
          enddo; enddo; enddo; enddo; enddo
          msq(1, 5, [1,2,3,4], 1, 1) = [1d0,1d0,1d0,1d0]
                  write (*,*) "AFTER", j,k,l,m,n, msq(j,k,l,m,n)
              endif
      end subroutine
end module
% ifort -O1 -fopenmp -o test test.f90 testcase.f90 && ./test
 AFTER           1           5          -4           1           1
   1.0000000000000
Sometimes other entries get filled with additional garbage.
Good output:
 AFTER           1           5           1           1           1
   1.00000000000000
 AFTER           1           5           2           1           1
   1.00000000000000
 AFTER           1           5           3           1           1
   1.00000000000000
 AFTER           1           5           4           1           1
   1.00000000000000
If it matters, this was tested with Linux ifort 19.0.5.281 and 19.0.2.187
Tobias
Tobias
Sorry, but I'm bumping this from the second page to first! Could someone try to reproduce this, so this can be either reported as a bug or as some stupidity of mine?
jimdempseyatthecove
IVF 2020, MS VS 2019, Win 7, x64 platform
Debug build no OpenMP
 AFTER           1           5           1           1           1
   1.00000000000000
 AFTER           1           5           2           1           1
   1.00000000000000
 AFTER           1           5           3           1           1
   1.00000000000000
 AFTER           1           5           4           1           1
   1.00000000000000
Press any key to continue . . .
Release build, no OpenMP
 AFTER           1           5           1           1           1
   1.00000000000000
 AFTER           1           5           2           1           1
   1.00000000000000
 AFTER           1           5           3           1           1
   1.00000000000000
 AFTER           1           5           4           1           1
   1.00000000000000
Debug with OpenMP
 AFTER           1           5           1           1           1
   1.00000000000000
 AFTER           1           5           2           1           1
   1.00000000000000
 AFTER           1           5           3           1           1
   1.00000000000000
 AFTER           1           5           4           1           1
   1.00000000000000
Release with OpenMP
 AFTER           1           5           1           1           1
   1.00000000000000
 AFTER           1           5           2           1           1
   1.00000000000000
 AFTER           1           5           3           1           1
   1.00000000000000
 AFTER           1           5           4           1           1
   1.00000000000000
Release with OpenMP, custom optimization, /O1
 AFTER           1           5           1           1           1
   1.00000000000000
 AFTER           1           5           2           1           1
   1.00000000000000
 AFTER           1           5           3           1           1
   1.00000000000000
 AFTER           1           5           4           1           1
   1.00000000000000
Using older version:
Intel® Parallel Studio XE 2019 Update 3 Composer Edition for Fortran Windows* Integration for Microsoft Visual Studio* 2013,
Version 19.0.0051.12, Copyright © 2002-2019 Intel Corporation. All rights reserved.
OpenMP, Release, Custom, /O1
 AFTER           1           5           1           1           1
   1.00000000000000
 AFTER           1           5           2           1           1
   1.00000000000000
 AFTER           1           5           3           1           1
   1.00000000000000
 AFTER           1           5           4           1           1
   1.00000000000000
This appears to work as intended.
Not sure why Intel PS XE update 3 shows Version 19.0.0051.12
Jim Dempsey
jimdempseyatthecove
Note, original code did not have a parallel region prior to test. IVF 19u3 Release with:
program main
        use omp_lib
      use test
      implicit none
      !$omp parallel
      !$omp master
      print *,"omp_get_num_threads()",omp_get_num_threads()
      !$omp end master
      !$omp end parallel
      msq = 0d0
end program
 omp_get_num_threads()           8
 AFTER           1           5           1           1           1
   1.00000000000000
 AFTER           1           5           2           1           1
   1.00000000000000
 AFTER           1           5           3           1           1
   1.00000000000000
 AFTER           1           5           4           1           1
   1.00000000000000
Not sure what your problem is.
Jim Dempsey
Tobias
Neither am I, but this points more towards Linux systems now? (I have tested this on two Linux systems with the above mentioned ifort versions)
