29653 Discussions
Strange result with polymorphic variables
Arjen_Markus
the program below gives the following output:
Two-dimensional walk:
-1.0295 -0.9157
-0.9369 -0.8480
-0.9698 -0.7649
-0.9106 -0.6984
-0.9416 -0.6242
-1.0236 -0.5465
-0.9835 -0.4996
-1.0234 -0.5896
-0.9418 -0.6701
-1.0337 -0.7531
Three-dimensional walk:
0.2000 0.7713 -0.8487
0.2705 0.6955 -0.8487
0.3261 0.5994 -0.8487
0.4251 0.6502 -0.8487
0.4569 0.6580 -0.8487
0.5248 0.5630 -0.8487
0.5419 0.6165 -0.8487
0.5838 0.6754 -0.8487
0.5256 0.7216 -0.8487
0.5700 0.6639 -0.8487
Where I expect the third column to vary just as the other two, it remains constant.
I may be missing something, but the output is more to what I expect if I use gfortran
(this has a different problem though).
Can anyone shed some light on this issue?
For your information: I use Intel Fortran 12.0.3 on Linux.
Arjen
! random_walk.f90 --
! Simulate a random walk in two and three dimensions
module points2d3d
implicit none
type point2d
real :: x, y
contains
procedure :: print => print_2d
procedure :: random_vector => random_vector_2d
procedure :: add_vector => add_vector_2d
procedure, pass(vector) :: scale_by_factor => scale_by_factor_2d
procedure :: assign => assign_2d
generic :: operator(+) => add_vector
generic :: operator(*) => scale_by_factor
generic :: assignment(=) => assign
end type point2d
type, extends(point2d) :: point3d
real :: z
contains
procedure :: print => print_3d
procedure :: random_vector => random_vector_3d
procedure :: add_vector => add_vector_3d
procedure, pass(vector) :: scale_by_factor => scale_by_factor_3d
procedure :: assign => assign_3d
end type point3d
contains
! Auxiliary routine to convert from class to point
subroutine assign_2d( point1, point2 )
class(point2d), intent(inout) :: point1
class(point2d), intent(in) :: point2
point1%x = point2%x
point1%y = point2%y
end subroutine assign_2d
subroutine assign_3d( point1, point2 )
class(point3d), intent(inout) :: point1
point1%x = point2%x
point1%y = point2%y
point1%z = 0.0
select type (point2)
class is (point3d)
point1%z = point2%z
end select
end subroutine assign_3d
subroutine print_2d( point )
class(point2d) :: point
write(*,'(2f10.4)') point%x, point%y
end subroutine print_2d
subroutine print_3d( point )
class(point3d) :: point
write(*,'(3f10.4)') point%x, point%y, point%z
end subroutine print_3d
subroutine random_vector_2d( point )
call random_number( point%x )
call random_number( point%y )
point%x = 2.0 * (point%x - 0.5)
point%y = 2.0 * (point%y - 0.5)
end subroutine random_vector_2d
subroutine random_vector_3d( point )
call point%point2d%random_vector
call random_number( point%z )
point%z = 2.0 * (point%z - 0.5)
end subroutine random_vector_3d
function add_vector_2d( point, vector )
class(point2d), intent(in) :: point, vector
class(point2d), allocatable :: add_vector_2d
allocate( add_vector_2d )
add_vector_2d%x = point%x + vector%x
add_vector_2d%y = point%y + vector%y
end function add_vector_2d
function add_vector_3d( point, vector )
class(point3d), intent(in) :: point
class(point2d), intent(in) :: vector
class(point2d), allocatable :: add_vector_3d
class(point3d), allocatable :: add_result
allocate( add_result )
select type (vector)
class is (point3d)
!add_result%point2d = point%point2d + vector%point2d
add_result%point2d = point%point2d%add_vector( vector%point2d )
add_result%z = point%z + vector%z
class default
add_result%z = 0.0
end select
call move_alloc( add_result, add_vector_3d )
end function add_vector_3d
function scale_by_factor_2d( factor, vector )
real, intent(in) :: factor
class(point2d), allocatable :: scale_by_factor_2d
allocate( scale_by_factor_2d )
scale_by_factor_2d%x = factor * vector%x
scale_by_factor_2d%y = factor * vector%y
end function scale_by_factor_2d
function scale_by_factor_3d( factor, vector )
class(point3d), intent(in) :: vector
class(point2d), allocatable :: scale_by_factor_3d
class(point3d), allocatable :: scale_result
allocate( scale_result )
scale_result%point2d = factor * vector%point2d
scale_result%z = factor * vector%z
call move_alloc( scale_result, scale_by_factor_3d )
end function scale_by_factor_3d
end module points2d3d
program random_walk
use points2d3d ! Both 2D and 3D points available
type(point2d), target :: point_2d
type(point3d), target :: point_3d
type(point2d), target :: vector_2d
type(point3d), target :: vector_3d
! A variable of class point2d can point to point_2d but
! also to point_3d
class(point2d), pointer :: point
class(point2d), pointer :: vector
integer :: nsteps = 10
integer :: i
integer :: trial
real :: deltt = 0.1
do trial = 1,2
! Select what type of point ...
if ( trial == 1 ) then
point => point_2d
vector => vector_2d
write(*,*) 'Two-dimensional walk:'
else
point => point_3d
vector => vector_3d
write(*,*) 'Three-dimensional walk:'
endif
call point%random_vector
do i = 1,nsteps
call vector%random_vector
point = point + deltt * vector
call point%print
enddo
enddo
end program random_walk
reinhold-bader
New Contributor II
my impression is that ifort gets the dispatch for the generic wrong. It should, for example, invoke the 3D vector add, and from there the 2D vector add. However, it directly invokes the 3D vector add from the main program even though the dynamic type of "point" is point3d. This error persists through more recent releases of the compiler.
Reinhold
This problem sounds vaguely familiar - I am looking at it now.
