Strange OpenMP bug
fah10
Hi, I just want to report a very strange OpenMP related bug.
The program listed below produces random output within the parallel region, e.g.
> ifort -openmp omp_strange.F90 && OMP_NUM_THREADS=1 ./a.out
42
-261231752
The bug occurs with Intel Fortran 11.1 20101201
Versions 11.0 20090609 and 12.0.0 20101116 are not affected.
The following things seem to be necessary to reproduce the bug:
- the default initialization of the pointer in the derived type
- declaring a variable of type tt in the main program (which may be unused)
- parallel region in a subroutine with a local variable of type tt
Here's the code:
[fortran]program omp_strange
   implicit none
   type tt
      integer :: i
      integer, pointer :: ip => null()
   end type tt
   type(tt) :: unused_variable
   call test()
contains
   subroutine test
      type(tt) :: v
      v%i = 42
      print*,v%i
      !$omp parallel shared(v)
      print*,v%i
      !$omp end parallel
   end subroutine test
end program omp_strange[/fortran]
If the problem is not in 12.0, it won't be looked at. Please use the current version. I tried this in the forthcoming Update 6 and it worked ok there as well.
