29240 討論
ifort12+openmp+return before "C$OMP PARALLEL DO" = "**Internal compiler error: segmentation violation signal raised** "
Yakov_Mindelis
初學者
532 檢視
This forum is the closest to "bug report" I got. If there's a facility to submit bugs, please point me at it ...
The code:
[fxfortran]      SUBROUTINE INITWDIS(IDIM,JDIM,KDIM,WDIS)
C
      REAL WDIS(IDIM,JDIM,KDIM)
C
#ifdef FAIL
      RETURN
#else
      if(1 .EQ. 1) RETURN
#endif
C
C$OMP PARALLEL DO PRIVATE(K,J,I)
      DO K = 1, KDIM
         DO J = 1, JDIM
            DO I = 1, IDIM
               DIS = 1.0E66
C
            END DO
         END DO
      END DO
C
      RETURN
      END
C[/fxfortran]
when compiling using this command ("RETURN" statement is conditioned by an "IF"), all is well:
[bash]ifort -fpp -DHAVESECNDS -DHAVEVARINFORMAT -extend_source -DNESTEDOMP -openmp -r8 -m64 -c ifort12_fail.f [/bash]
when compiling using this command ("RETURN" statement is alone), internal compiler error occurs:
[bash]ifort -fpp -DHAVESECNDS -DHAVEVARINFORMAT -extend_source -DNESTEDOMP -openmp -r8 -m64 -c ifort12_fail.f  -DFAIL[/bash]
without
[bash]-openmp[/bash]
the code compiles OK.
Edit:
Compilers involved: 12.0.5 on MACOS, 12.0.4 on Linux x86_64
TIA,
Jack
0 積分
2 回應
TimP
榮譽貢獻者 III
532 檢視
Granted, wrong code should produce an error diagnostic, not an internal error. I don't see how you could say "compiles OK" without fixing the source code.
I can get an internal error when I don't set -fpp, but not with that option.
532 檢視
I can reproduce this and will escalate it to development. I assume that this is not a blocking issue for you. Issu ID is DPD200172987.
You can submit bugs here or, if you have a current support license, through Intel Premier Support. Click the Tech Support link on this forum's main page for more information.
回覆
