internal comp. error for lapack
pivo12
compiling the inserted file 'clatm5.f' (which is a part of LAPACK distribution) I am encountering th following error:
ifort -xAVX -arch AVX -parallel -c clatm5.f
0_909
: catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for clatm5.f (code 1)
But when I don't use -AVX options (eg. ifort -parallel -c clatm5.f) compiles smoothly.
Intel Fortran Intel 64 Compiler XE for applications running on Intel 64, Version 12.0.4.191 Build 20110427
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
FOR NON-COMMERCIAL USE ONLY
Slackware Linux 64bit
Kernel version 2.6.37.6
gcc version 4.5.2
LAPCK version 3.3.1
Intel Core i5-2400 proc.
Tamas I.
[bash]      SUBROUTINE CLATM5( PRTYPE, M, N, A, LDA, B, LDB, C, LDC, D, LDD,
     $                   E, LDE, F, LDF, R, LDR, L, LDL, ALPHA, QBLCKA,
     $                   QBLCKB )
*  -- LAPACK test routine (version 3.1) --
*     Univ. of Tennessee, Univ. of California Berkeley and NAG Ltd..
*     November 2006
*     .. Scalar Arguments ..
      INTEGER            LDA, LDB, LDC, LDD, LDE, LDF, LDL, LDR, M, N,
     $                   PRTYPE, QBLCKA, QBLCKB
      REAL               ALPHA
*     .. Array Arguments ..
      COMPLEX            A( LDA, * ), B( LDB, * ), C( LDC, * ),
     $                   D( LDD, * ), E( LDE, * ), F( LDF, * ),
     $                   L( LDL, * ), R( LDR, * )
*  Purpose
*  CLATM5 generates matrices involved in the Generalized Sylvester
*  equation:
*      A * R - L * B = C
*      D * R - L * E = F
*  They also satisfy (the diagonalization condition)
*   [ I -L ] ( [ A  -C ], [ D -F ] ) [ I  R ] = ( [ A    ], [ D    ] )
*   [    I ] ( [     B ]  [    E ] ) [    I ]   ( [    B ]  [    E ] )
*  Arguments
*  PRTYPE  (input) INTEGER
*          "Points" to a certian type of the matrices to generate
*          (see futher details).
*  M       (input) INTEGER
*          Specifies the order of A and D and the number of rows in
*          C, F,  R and L.
*  N       (input) INTEGER
*          Specifies the order of B and E and the number of columns in
*          C, F, R and L.
*  A       (output) COMPLEX array, dimension (LDA, M).
*          On exit A M-by-M is initialized according to PRTYPE.
*  LDA     (input) INTEGER
*          The leading dimension of A.
*  B       (output) COMPLEX array, dimension (LDB, N).
*          On exit B N-by-N is initialized according to PRTYPE.
*  LDB     (input) INTEGER
*          The leading dimension of B.
*  C       (output) COMPLEX array, dimension (LDC, N).
*          On exit C M-by-N is initialized according to PRTYPE.
*  LDC     (input) INTEGER
*          The leading dimension of C.
*  D       (output) COMPLEX array, dimension (LDD, M).
*          On exit D M-by-M is initialized according to PRTYPE.
*  LDD     (input) INTEGER
*          The leading dimension of D.
*  E       (output) COMPLEX array, dimension (LDE, N).
*          On exit E N-by-N is initialized according to PRTYPE.
*  LDE     (input) INTEGER
*          The leading dimension of E.
*  F       (output) COMPLEX array, dimension (LDF, N).
*          On exit F M-by-N is initialized according to PRTYPE.
*  LDF     (input) INTEGER
*          The leading dimension of F.
*  R       (output) COMPLEX array, dimension (LDR, N).
*          On exit R M-by-N is initialized according to PRTYPE.
*  LDR     (input) INTEGER
*          The leading dimension of R.
*  L       (output) COMPLEX array, dimension (LDL, N).
*          On exit L M-by-N is initialized according to PRTYPE.
*  LDL     (input) INTEGER
*          The leading dimension of L.
*  ALPHA   (input) REAL
*          Parameter used in generating PRTYPE = 1 and 5 matrices.
*  QBLCKA  (input) INTEGER
*          When PRTYPE = 3, specifies the distance between 2-by-2
*          blocks on the diagonal in A. Otherwise, QBLCKA is not
*          referenced. QBLCKA > 1.
*  QBLCKB  (input) INTEGER
*          blocks on the diagonal in B. Otherwise, QBLCKB is not
*          referenced. QBLCKB > 1.
*  Further Details
*  PRTYPE = 1: A and B are Jordan blocks, D and E are identity matrices
*             A : if (i == j) then A(i, j) = 1.0
*                 if (j == i + 1) then A(i, j) = -1.0
*                 else A(i, j) = 0.0,            i, j = 1...M
*             B : if (i == j) then B(i, j) = 1.0 - ALPHA
*                 if (j == i + 1) then B(i, j) = 1.0
*                 else B(i, j) = 0.0,            i, j = 1...N
*             D : if (i == j) then D(i, j) = 1.0
*                 else D(i, j) = 0.0,            i, j = 1...M
*             E : if (i == j) then E(i, j) = 1.0
*                 else E(i, j) = 0.0,            i, j = 1...N
*             L =  R are chosen from [-10...10],
*                  which specifies the right hand sides (C, F).
*  PRTYPE = 2 or 3: Triangular and/or quasi- triangular.
*             A : if (i <= j) then A(i, j) = [-1...1]
*                 if (PRTYPE = 3) then
*                    A(k + 1, k + 1) = A(k, k)
*                    A(k + 1, k) = [-1...1]
*                    sign(A(k, k + 1) = -(sin(A(k + 1, k))
*                        k = 1, M - 1, QBLCKA
*             B : if (i <= j) then B(i, j) = [-1...1]
*                    B(k + 1, k + 1) = B(k, k)
*                    B(k + 1, k) = [-1...1]
*                    sign(B(k, k + 1) = -(sign(B(k + 1, k))
*                        k = 1, N - 1, QBLCKB
*             D : if (i <= j) then D(i, j) = [-1...1].
*             E : if (i <= j) then D(i, j) = [-1...1]
*                 L, R are chosen from [-10...10],
*  PRTYPE = 4 Full
*             A(i, j) = [-10...10]
*             D(i, j) = [-1...1]    i,j = 1...M
*             B(i, j) = [-10...10]
*             E(i, j) = [-1...1]    i,j = 1...N
*             R(i, j) = [-10...10]
*             L(i, j) = [-1...1]    i = 1..M ,j = 1...N
*             L, R specifies the right hand sides (C, F).
*  PRTYPE = 5 special case common and/or close eigs.
*     .. Parameters ..
      COMPLEX            ONE, TWO, ZERO, HALF, TWENTY
      PARAMETER          ( ONE = ( 1.0E+0, 0.0E+0 ),
     $                   TWO = ( 2.0E+0, 0.0E+0 ),
     $                   ZERO = ( 0.0E+0, 0.0E+0 ),
     $                   HALF = ( 0.5E+0, 0.0E+0 ),
     $                   TWENTY = ( 2.0E+1, 0.0E+0 ) )
*     .. Local Scalars ..
      INTEGER            I, J, K
      COMPLEX            IMEPS, REEPS
*     .. Intrinsic Functions ..
      INTRINSIC          CMPLX, MOD, SIN
*     .. External Subroutines ..
      EXTERNAL           CGEMM
*     .. Executable Statements ..
      IF( PRTYPE.EQ.1 ) THEN
         DO 20 I = 1, M
            DO 10 J = 1, M
               IF( I.EQ.J ) THEN
                  A( I, J ) = ONE
                  D( I, J ) = ONE
               ELSE IF( I.EQ.J-1 ) THEN
                  A( I, J ) = -ONE
                  D( I, J ) = ZERO
               ELSE
                  A( I, J ) = ZERO
                  D( I, J ) = ZERO
               END IF
   10       CONTINUE
   20    CONTINUE
         DO 40 I = 1, N
            DO 30 J = 1, N
               IF( I.EQ.J ) THEN
                  B( I, J ) = ONE - ALPHA
                  E( I, J ) = ONE
                  B( I, J ) = ONE
                  E( I, J ) = ZERO
               ELSE
                  B( I, J ) = ZERO
                  E( I, J ) = ZERO
               END IF
   30       CONTINUE
   40    CONTINUE
         DO 60 I = 1, M
            DO 50 J = 1, N
               R( I, J ) = ( HALF-SIN( CMPLX( I / J ) ) )*TWENTY
               L( I, J ) = R( I, J )
   50       CONTINUE
   60    CONTINUE
      ELSE IF( PRTYPE.EQ.2 .OR. PRTYPE.EQ.3 ) THEN
         DO 80 I = 1, M
            DO 70 J = 1, M
               IF( I.LE.J ) THEN
                  A( I, J ) = ( HALF-SIN( CMPLX( I ) ) )*TWO
                  D( I, J ) = ( HALF-SIN( CMPLX( I*J ) ) )*TWO
               ELSE
                  A( I, J ) = ZERO
                  D( I, J ) = ZERO
               END IF
   70       CONTINUE
   80    CONTINUE
         DO 100 I = 1, N
            DO 90 J = 1, N
               IF( I.LE.J ) THEN
                  B( I, J ) = ( HALF-SIN( CMPLX( I+J ) ) )*TWO
                  E( I, J ) = ( HALF-SIN( CMPLX( J ) ) )*TWO
               ELSE
                  B( I, J ) = ZERO
                  E( I, J ) = ZERO
               END IF
   90       CONTINUE
  100    CONTINUE
         DO 120 I = 1, M
            DO 110 J = 1, N
               R( I, J ) = ( HALF-SIN( CMPLX( I*J ) ) )*TWENTY
               L( I, J ) = ( HALF-SIN( CMPLX( I+J ) ) )*TWENTY
  110       CONTINUE
  120    CONTINUE
         IF( PRTYPE.EQ.3 ) THEN
            IF( QBLCKA.LE.1 )
     $         QBLCKA = 2
            DO 130 K = 1, M - 1, QBLCKA
               A( K+1, K+1 ) = A( K, K )
               A( K+1, K ) = -SIN( A( K, K+1 ) )
  130       CONTINUE
            IF( QBLCKB.LE.1 )
     $         QBLCKB = 2
            DO 140 K = 1, N - 1, QBLCKB
               B( K+1, K+1 ) = B( K, K )
               B( K+1, K ) = -SIN( B( K, K+1 ) )
  140       CONTINUE
         END IF
      ELSE IF( PRTYPE.EQ.4 ) THEN
         DO 160 I = 1, M
            DO 150 J = 1, M
               A( I, J ) = ( HALF-SIN( CMPLX( I*J ) ) )*TWENTY
               D( I, J ) = ( HALF-SIN( CMPLX( I+J ) ) )*TWO
  150       CONTINUE
  160    CONTINUE
         DO 180 I = 1, N
            DO 170 J = 1, N
               B( I, J ) = ( HALF-SIN( CMPLX( I+J ) ) )*TWENTY
               E( I, J ) = ( HALF-SIN( CMPLX( I*J ) ) )*TWO
  170       CONTINUE
  180    CONTINUE
         DO 200 I = 1, M
            DO 190 J = 1, N
               R( I, J ) = ( HALF-SIN( CMPLX( J / I ) ) )*TWENTY
               L( I, J ) = ( HALF-SIN( CMPLX( I*J ) ) )*TWO
  190       CONTINUE
  200    CONTINUE
      ELSE IF( PRTYPE.GE.5 ) THEN
         REEPS = HALF*TWO*TWENTY / ALPHA
         IMEPS = ( HALF-TWO ) / ALPHA
         DO 220 I = 1, M
            DO 210 J = 1, N
               R( I, J ) = ( HALF-SIN( CMPLX( I*J ) ) )*ALPHA / TWENTY
               L( I, J ) = ( HALF-SIN( CMPLX( I+J ) ) )*ALPHA / TWENTY
  210       CONTINUE
  220    CONTINUE
         DO 230 I = 1, M
            D( I, I ) = ONE
  230    CONTINUE
         DO 240 I = 1, M
            IF( I.LE.4 ) THEN
               A( I, I ) = ONE
               IF( I.GT.2 )
     $            A( I, I ) = ONE + REEPS
               IF( MOD( I, 2 ).NE.0 .AND. I.LT.M ) THEN
                  A( I, I+1 ) = IMEPS
               ELSE IF( I.GT.1 ) THEN
                  A( I, I-1 ) = -IMEPS
               END IF
            ELSE IF( I.LE.8 ) THEN
               IF( I.LE.6 ) THEN
                  A( I, I ) = REEPS
               ELSE
                  A( I, I ) = -REEPS
               END IF
                  A( I, I+1 ) = ONE
                  A( I, I-1 ) = -ONE
               END IF
            ELSE
               A( I, I ) = ONE
                  A( I, I+1 ) = IMEPS*2
                  A( I, I-1 ) = -IMEPS*2
               END IF
            END IF
  240    CONTINUE
         DO 250 I = 1, N
            E( I, I ) = ONE
            IF( I.LE.4 ) THEN
               B( I, I ) = -ONE
               IF( I.GT.2 )
     $            B( I, I ) = ONE - REEPS
               IF( MOD( I, 2 ).NE.0 .AND. I.LT.N ) THEN
                  B( I, I+1 ) = IMEPS
                  B( I, I-1 ) = -IMEPS
               END IF
               IF( I.LE.6 ) THEN
                  B( I, I ) = REEPS
               ELSE
                  B( I, I ) = -REEPS
               END IF
                  B( I, I+1 ) = ONE + IMEPS
                  B( I, I-1 ) = -ONE - IMEPS
               END IF
            ELSE
                  B( I, I+1 ) = IMEPS*2
                  B( I, I-1 ) = -IMEPS*2
               END IF
            END IF
  250    CONTINUE
      END IF
*     Compute rhs (C, F)
      CALL CGEMM( 'N', 'N', M, N, M, ONE, A, LDA, R, LDR, ZERO, C, LDC )
      CALL CGEMM( 'N', 'N', M, N, N, -ONE, L, LDL, B, LDB, ONE, C, LDC )
      CALL CGEMM( 'N', 'N', M, N, M, ONE, D, LDD, R, LDR, ZERO, F, LDF )
      CALL CGEMM( 'N', 'N', M, N, N, -ONE, L, LDL, E, LDE, ONE, F, LDF )
*     End of CLATM5
      END
[/bash]
mecej4
The same error occurs with the Windows 12.0.5.221 versions (IA32 as well as X64) of the compiler with the command line
C:\> ifort /QxAVX /arch:AVX /Qparallel /c clamt5.f
but no error occurs when the /Qparallel option is left out.
TimP
I found it difficult to save a compilable version from this post.
I note that this internal error appears to result from the combination of /Qparallel with auto-vectorization. With a newer (generally buggier) compiler, I don't get the internal error.
I don't know what should happen when you set /QxAVX /arch:AVX . I would interpret that as setting aggressive AVX compilation for Intel only over-ridden by less aggressive AVX code generation without the Intel-AVX-only run-time check.
I can reproduce the error in 12.0.5 but not in 12.0.6, which I expect to be available next week.
