This forum is the closest to "bug report" I got. If there's a facility to submit bugs, please point me at it ...
The code:
when compiling using this command ("RETURN" statement is alone), internal compiler error occurs:
without
the code compiles OK.
Edit:
Compilers involved: 12.0.5 on MACOS, 12.0.4 on Linux x86_64
TIA,
Jack
The code:
[fxfortran] SUBROUTINE INITWDIS(IDIM,JDIM,KDIM,WDIS) C REAL WDIS(IDIM,JDIM,KDIM) C #ifdef FAIL RETURN #else if(1 .EQ. 1) RETURN #endif C C$OMP PARALLEL DO PRIVATE(K,J,I) DO K = 1, KDIM DO J = 1, JDIM DO I = 1, IDIM DIS = 1.0E66 C END DO END DO END DO C RETURN END C[/fxfortran]when compiling using this command ("RETURN" statement is conditioned by an "IF"), all is well:
[bash]ifort -fpp -DHAVESECNDS -DHAVEVARINFORMAT -extend_source -DNESTEDOMP -openmp -r8 -m64 -c ifort12_fail.f [/bash]
[bash]ifort -fpp -DHAVESECNDS -DHAVEVARINFORMAT -extend_source -DNESTEDOMP -openmp -r8 -m64 -c ifort12_fail.f -DFAIL[/bash]
without
[bash]-openmp[/bash]
Edit:
TIA,
Jack
Granted, wrong code should produce an error diagnostic, not an internal error. I don't see how you could say "compiles OK" without fixing the source code.
I can get an internal error when I don't set -fpp, but not with that option.
I can reproduce this and will escalate it to development. I assume that this is not a blocking issue for you. Issu ID is DPD200172987.
You can submit bugs here or, if you have a current support license, through Intel Premier Support. Click the Tech Support link on this forum's main page for more information.
![](/skins/images/D2683F18326913BBA0436CB7114DD569/responsive_peak/images/icon_anonymous_message.png)
Topic Options
