29641 Discussions
Strange stack error causes program terminated without an error
yang__xiaodong
I'm an experienced fortran programmer, yet a really strange problem confused me.
As mentioned, the program terminates occasionally after the output
"============================ start performing inversion ..."
It seems a stack smash occurs.
The visual studio 2019 project (with oneapi 2021.3 installed) and needed files are attached. You could run the program with
DCFI3D -a mod1
MKL libraries are needed. Could anyone help find the error? Thanks very much.
yang__xiaodong
Okay, now I find where the problem is.
It is because that when I use the MKL subroutine mkl_sparse_d_mm that has a proto of
stat = mkl_sparse_d_mm (operation, alpha,A, descr, layout, B, columns, ldb,beta, C,ldc)
I declare the variable columns larger than what I need. Thus, it results in a C which takes more memory space than expected. This further causes heap corruption, and no error message could be generated by the Fortran compiler.
jimdempseyatthecove
Yang, I wish to thank you for replying with the solution to your problem. This is valuable information for others reading this forum thread.
Jim Dempsey
JohnNichols
Honored Contributor I
@yang__xiaodong  - jolly well done.
Next question, what are you using the mesh for?
yang__xiaodong
HAPPY solving the problem.
The mesh is used for finite element solving of a large size 3-D direct current electrostatic problem. In which geophysicists eject electric current into the ground, and voltages are measured elsewhere.
As a boundary condition V=0 is applied, the mesh must be large enough to ensure the voltage shrinks.
I think, why the error is hard to find, is because that the MKL interface, including the mkl_sparse_d_mm subroutine, may have a C proto and then be converted to Fortran. Thus, not enough info could be captured by the Fortran compiler.
