Strangely long compilation time
Arjen_Markus
a colleague of mine is experiencing bizarrely long compilation times for one particular
file - more than a minute whereas if I compile it with the same version of the Intel compiler
it takes less than a second.
The file is several 100s of lines of code, but nothing specifically complex, and it includes
a few other source files. I estimate the total number of lines to be 3000.
If the compilation time had been consistently long, I could have imagined that there
was something awkward in the source code, but that is not the case. It is just on this
one laptop where it is taking so long (I tried two other machines myself and another
colleague does not experience it either).
The compilation time drops to 1 second or thereabout if we remove the included files.
Any suggestions as to what might be slowing down the compilation process? Should
we reinstall the compiler?
Arjen
Look at his INCLUDE path and see if there are network shares on it. Are the include files in the same folder as the source? Are these on a local disk or network share?
Arjen_Markus
That should not matter: my own experiment was on a network drive. Besides the project only uses files
and include directories and the like from the directory tree that contains it.
Oh, the compiler version is Intel Fortran 11.0.072
Arjen
It could matter. Please try again with files local and no network shares on the INCLUDE path and see if the behavior changes.
Arjen_Markus
Okay, Steve,
I will ask him to do that experiment.
Arjen
Arjen_Markus
Hi Steve,
it turns out that the disk on which he worked was encrypted (laptops get stolen :() - this encryption software
normally does not have any impact on the performance, but curiously enough in this case it had a great
impact.
Thanks for pointing us to the solution.
Arjen
That's great news. For what it's worth, all of our laptops use PGP Whole Disk Encryption and I frequently do Fortran builds on mine without noticing any slowdown.
Arjen_Markus
Well, my colleague uses Trucrypt, but only this particular file seems to be affected.
Anyway, the riddle is brought back to manageable proportions ;)
Arjen
Arjen_Markus
Some further information: the long compile time happens if optimisation is in effect.
The inclusion of the files makesfour subroutines internal. Can that have such a large
effect?
Arjen
I have no idea why that should matter, unless the disk encryption really slows down disk writes.
Arjen_Markus
If it does, then it is still odd that it should happen with that particular file and that set of compiler options.
At least we now know what was causing the delay.
Arjen
