String Function Equivalents
Intel_C_Intel
Does anybody know if there is an equivalent to 'VERIFY' in C / C++?
Cheers,
Dan
TimP
I don't believe there is a standard C function close to that name. I'll guess that you're looking for something akin to strcspn() or the Cobol verify, not the verify function which comes up under info. These string functions can be written in terms of INDEX(), and the efficiency could be fairly good with compilers which do some form of in-line expansion. You might be interested in what you could find with a Google search on Fortran INDEX().
Intel_C_Intel
nVerify = VERIFY(privid, VALID_CHARS)
DO WHILE (nVerify > 0)
privid(nVerify:nVerify) = '_'
END DO
Intel_C_Intel
What I tried to say...I'm not to bothered about efficiecny since this is (MFC) GUI code, so for:
END DO
I used CString functions:
for (int i = 0; i < m_strItemName.GetLength(); i++)
chr = m_strItemName.GetAt(i);
nLoc = strValid.Find(chr, 0);
if (-1 == nLoc)
m_strItemName.SetAt(i, '_');
which seems a little less elegant, but works ok.
Thanks anyway,
Dan
