help with internal write
kkajino
program test
integer Num
character NumTex*6
Num=123450
!write(UNIT=numtex,fmt=('a6')) num
!write(UNIT=numtex,fmt=('i6')) num
write(UNIT=numtex,fmt=*) num
write(*,*) numtex
end
After reading the manual on internal writes, I wrote the above test program to try it, but, one of the above internal write statements work.
When I use fmt=*, I get the error, "output statement overflow record, unit -5, file internal list-directed write".
When I use fmt=('a6'), I get a syntax error on the formatting during runtime.
Could anyone point out what I'm doing wrong?
I'm using compaq visual fortran v6.6 on windows XP.
Kent
pjrichar
Try
program test
integer Num
character NumTex*6
Num=123450
write(numtex,'(a6)') num
write(numtex,'(i6)') num
stop
end
kkajino
Thanks for the help.
'(i6)' gave me the correct result. '(a6)' gave me a smiley-face. : )
