29657 Discussions
Structure constructor with UNION ... END UNION
kramer__walter
I get the following error message for a structure constructor of a derived type:
error #8212: Omitted field is not initialized. Field initialization missing: [RR143]
However, RR143 is not an additional field, but amapping. Am I missing something or is this a compiler problem?
Before Iused equivalence to mapan instance of the derived type and the array representationin the same memory. Since this presented serious problems (which are actually resolved in 11.1.051) I tried the UNION..END UNION, which obviously resulted in a different kind of problem. What would be the preferred method anyway, equivalencing or using UNION .. ENDUNION (provided the issue with the structure constructor is resolved)?
The constructor looks like this:
RC143=ST143(' ',(/' ',' ',' '/),0.,0.,0.,0.,0., &
0.,0.,0.,0.,0.,0.,0.,0.,0.,0.,0.,0.,0.,0)
and the derived type declaration looks like this:
TYPE ST143
SEQUENCE
UNION
MAP
CHARACTER(4) IDF
CHARACTER(4) NAME(3)
REAL(4) TFL1
REAL(4) TFLX
REAL(4) DTMX
REAL(4) FFL
REAL(4) CPFL
REAL(4) UA
REAL(4) WFH
REAL(4) XT
REAL(4) DUA
REAL(4) TFL2
REAL(4) WCFL
REAL(4) WCS
REAL(4) CPS
REAL(4) XNTU
REAL(4) CAR
REAL(4) EFF
REAL(4) TS2
REAL(4) XLMTD
INTEGER(4) IP2
END MAP
MAP
REAL(4) RR143(23)
END MAP
END UNION
END TYPE
TYPE(ST143) RC143
Walter Kramer
jimdempseyatthecove
TYPE ST143_FIELDS
SEQUENCE
CHARACTER(4) IDF
REAL(4) TFL1
REAL(4) TFLX
REAL(4) DTMX
REAL(4) FFL
REAL(4) CPFL
REAL(4) UA
REAL(4) WFH
REAL(4) XT
REAL(4) DUA
REAL(4) TFL2
REAL(4) WCFL
REAL(4) WCS
REAL(4) CPS
REAL(4) XNTU
REAL(4) CAR
REAL(4) EFF
REAL(4) TS2
REAL(4) XLMTD
INTEGER(4) IP2
END TYPE ST143_FIELDS
TYPE ST143
UNION
MAP
TYPE(ST143_FIELDS) ::F
END MAP
MAP
REAL(4) RR143(23)
END MAP
END UNION
END TYPE ST143
TYPE(ST143) RC143
RC143%F=ST143_FIELDS(' ',(/' ',' ',' '/),0.,0.,0.,0.,0., &
Jim Demspey
kramer__walter
Hello Jim,
Thanks for the answer. Is this the way the developers have actually intended it or is it aworkaround?
It would mean that I now have to refer to a member of the structure as: RC143%F%FIELDNAME.
In that case I prefer the methodwith EQUIVALENCE.
I have also looked at the possibility to use TRANSFER (which may be feasible under some circumstances), however this results in more memory use and in my opinion to unnecessary copying of data. Moreover, the mold for copying data from the structure to a one dimensional array is fairly straightforward (RR143=TRANSFER(RC143, (/23*0.0/)), however if I want to copy the data back I need the mold based on structure ST143_FIELDS (and I have many of these structures all with different composition), or can I also use the type name "ST143_FIELDS" to represent the mold?
Walter Kramer
jimdempseyatthecove
Try a pointer
[cpp]TYPE ST143_FIELDS
  SEQUENCE
    CHARACTER(4) IDF
    REAL(4) TFL1
    REAL(4) TFLX
    REAL(4) DTMX
    REAL(4) FFL
    REAL(4) CPFL
    REAL(4) UA
    REAL(4) WFH
    REAL(4) XT
    REAL(4) DUA
    REAL(4) TFL2
    REAL(4) WCFL
    REAL(4) WCS
    REAL(4) CPS
    REAL(4) XNTU
    REAL(4) CAR
    REAL(4) EFF
    REAL(4) TS2
    REAL(4) XLMTD
    INTEGER(4) IP2
TYPE ST143_UNION
  UNION
    MAP
      TYPE(ST143_FIELDS) :: F
    END MAP
    MAP
      REAL(4) RR143(23)
    END MAP
  END UNION
END TYPE ST143_UNION
TYPE(ST143_UNION)    RC143_UNION
TYPE(ST143_FIELDS), POINTER :: RC143
RC143 => RC143_UNION ! done once
... RC143=ST143_FIELDS(' ',(/' ',' ',' '/),0.,0.,0.,0.,0., & 0.,0.,0.,0.,0.,0.,0.,0.,0.,0.,0.,0.,0.,0) ...
RC143%CPS = 12.34
Jim Dempsey
[/cpp]
This is the intended behavior. UNION, an extension, doesn't play well with certain standard language features, notably structure constructotrs. We spent a lot of time thinking about this exact issue and decided that the current behavior was the "least offensive", as there are some big problems that can occur if the behavior was otherwise.
kramer__walter
Thanks Jim, Steve
The issue is clear to me now,
Walter Kramer
