29562 Discussions
Subroutine or function as part of a derived type structure
OP1
New Contributor III
Is it possible to pass a function or subroutine as a component of a derived type variable? If so, how is it done?
Thanks in advance,
Olivier
thomas_boehme
New Contributor II
Quoting - opmkl
Thanks in advance,
Olivier
This is possible with Fortran 2003 using type-bound procedures. IVF has support for this in v11.1
The syntax is the following:
TYPE :: A
REAL :: val
CONTAINS
PROCEDURE :: PROC
END TYPE A
regards,
Thomas
Thomas describes what is called a type-bound procedure. This may or may not be what you want. The compiler also supports procedure pointers as components of a derived type.
OP1
New Contributor III
Thomas, Steve, thanks to both of you. The two suggested solutions would work well for what I want to do. I had kind of forgotten the procedure pointer technique, which was already available in previous versions of IVF and which I used in the past as well...
Thanks again- and have a nice day!
Olivier
