29649 Discussions
Syntax highlighting in Visual Studio 2008
erich_riegler
I installed Intel Visual Fortran Compiler Version 11.1.035. In this version the Fortran-commentlines starting with a "C" in the first column are not recognized as comments anymore(for syntax highlighting).
How can I resolve this ?
bendel_boy1
Was your file extension .f90 (freeform - C in the first column is not a comment) or .f/.for (fixed format - C in the first column is a comment).?
erich_riegler
Quoting - bendel boy
The file(s) are .f (fixed format).
This is a known problem if you have multiple projects and open the file from an error message, or perhaps some other ways. It will be fixed in a future update.
erich_riegler
But this worked well with the last Version of the Compiler we used !
So what has changed in the IDE-integration ?
I'm not sure what changed, and I can't be certain that you are seeing the same problem. If you create a new project with a fixed-form source file (.f) and open that file from the Solution Explorer pane, do you get the highlighting correct?
erich_riegler
Yes, in that case it works correct.
But in existing projects it does not, as it did until installing the new compiler version.
Erich
We will fix this in a future update, and apologize for the inconvenience.
I believe that this was fixed in Update 2 (11.1.046). Please try this and let me know.
