Including apostrophes in a READ
Stuart_M_
Hi folks
I need to read the following into variable from a text file: 'xml_input'C
The read needs to include the apostrophes and the C appended on the end, yet a simple READ of the line only returns the text within the apostrophes. I'm assuming the READ statement is ignoring the apostrophes and assuming that they are simply indicative of the boundaries of the text of interest. In our case they are not, and I need to include them as well as what appears outside of the apostrophes, in this case the "C".
Anyone know a sneaky way to achieve this?
Many thanks!
TimP
If you have tried only list-directed read, you'll probably need to read the entire line to a CHARACTER string usng A format, then find your string and copy it out by a CHARACTER assignment. Not very sneaky, somewhat old-fashioned.
DavidWhite
Valued Contributor II
Quoting - tim18
Are you able to embed the string in double-quotes (")
If so, you can use the DELIM attribute on the READ so that the single-quotes are ignored as text delimiters.
David
You cannot use list-directed input for this. I would agree with Tim's advice - read the whole line into a character variable and then "parse" it yourself, looking for delimiters that are correct for your line's syntax. It doesn't match anything Fortran can provide for you automatically.
Stuart_M_
Thanks everyone
I eventually used a formatted read (A) that picked up all the necessary characters. Thanks very much for the help :-)
