Superfluous GENERIC OPERATOR specification in extended derived type generated no errors or warnings
FortranFan
Dear Steve et al. at Intel,
Can you please review the code shown below and check whether it is ok to have a superfluous GENERIC OPERATOR specification in an extended derived type that is simply a copy of one in the abstract parent?  See lines 17 and 47 in the code snippet, a heavily simplified version of my actual type.
This code compiles without any errors or warnings in Intel Fortran XE 2013, Update 1 even if standards checking is turned on.
However, gfortran 4.9 flags an error saying the two procedures for the + operator are ambiguous.
It looks ok to me even though in my actual code, the specification in the child was just by accident, I have no need for it, and I've since removed it. But if gfortran is correct, it will help to get Intel Fortran to generate some sort of error or a warning.
Since a few other trouble incidents have come up recently in connection with resolution of ambiguous references in GENERIC statements in extended derived types, this example may possibly be of interest to your developers. If appropriate, please attach this to one or more of those tracking incidents.
Thanks much.
[fortran]
   MODULE m
      IMPLICIT NONE
      PRIVATE
      !.. Mnemonic constants
      INTEGER, PARAMETER, PUBLIC :: IMISS = -9999
      TYPE, ABSTRACT, PUBLIC :: p
         PRIVATE
      CONTAINS
         PRIVATE
         PROCEDURE(IAdd_p), PASS(Lhs), DEFERRED   :: Add_p
         PROCEDURE(IInit_p), PASS(This), DEFERRED, PUBLIC :: Init
         GENERIC, PUBLIC :: OPERATOR(+) => Add_p
      END TYPE p
      ABSTRACT INTERFACE
         PURE ELEMENTAL FUNCTION IAdd_p(Lhs, Rhs) RESULT(LhsPlusRhs)
            IMPORT :: p
            !.. Argument list
            CLASS(p), INTENT(IN)  :: Lhs
            CLASS(p), INTENT(IN)  :: Rhs
            !.. Function result
            CLASS(p), ALLOCATABLE :: LhsPlusRhs
         END FUNCTION IAdd_p
         PURE ELEMENTAL SUBROUTINE IInit_p(This, InitVal)
            IMPORT :: p
            !.. Argument list
            CLASS(p), INTENT(INOUT) :: This
            INTEGER, INTENT(IN)     :: InitVal
         END SUBROUTINE IInit_p
      END INTERFACE
      TYPE, EXTENDS(p), PUBLIC :: c
         PRIVATE
         INTEGER :: foo
      CONTAINS
         PRIVATE
         PROCEDURE, PASS(Lhs) :: Add_p => Add_c
         PROCEDURE, PASS(This), PUBLIC :: Init => Init_c
      END TYPE c
   CONTAINS
      PURE ELEMENTAL FUNCTION Add_c(Lhs, Rhs) RESULT(LhsPlusRhs)
         !.. Argument list
         CLASS(c), INTENT(IN)  :: Lhs
         !.. Function result
         !.. Local variables
         INTEGER :: Istat
         TYPE(c), ALLOCATABLE :: NewChild
         ALLOCATE(NewChild, SOURCE=Lhs, STAT=Istat)
         IF (Istat /= 0) THEN
            ALLOCATE( c :: LhsPlusRhs, STAT=Istat)
            IF (Istat == 0) THEN
               CALL LhsPlusRhs%Init(IMISS)
            END IF
            !.. Insert error handling here
            RETURN
         END IF
         SELECT TYPE(Rhs)
            CLASS IS (c)
               NewChild%foo = Lhs%foo + Rhs%foo
            CLASS DEFAULT
               !.. Not yet supported
               NewChild%foo = IMISS
         END SELECT
         CALL MOVE_ALLOC( NewChild, LhsPlusRhs )
         RETURN
      END FUNCTION Add_c
      PURE ELEMENTAL SUBROUTINE Init_c(This, InitVal)
         !.. Argument list
         CLASS(c), INTENT(INOUT) :: This
         This%foo = InitVal
         RETURN
      END SUBROUTINE Init_c
   END MODULE m
[/fortran]
Steven_L_Intel1
I can't identify any text in the standard forbidding this usage. You should ask the gfortran folks what the basis for the error is.
FortranFan
Thanks Steve for taking a look.  Will do as you suggest.
Steven_L_Intel1
I tried gfortran - it complains:
$ gfortran U508187.f90
U508187.f90:47.42:
                                          1
Error: 'add_c' and 'iadd_p' for GENERIC '+' at (1) are ambiguous
U508187.f90:65.18-35:
                  1                2
Error: Type of entity at (1) is type incompatible with source-expr at (2)
Then I tried NAG Fortran. It picked up on a problem neither ifort nor gfortran did:
Error: U508187.f90, line 22: Elemental function IADD_P must not be allocatable
Yes indeed:
C1290 The result variable of an elemental function shall be scalar, shall not have the POINTER or ALLOCATABLE attribute, and shall not have a type parameter that is defined by an expression that is not a constant expression.
If I rework the code to remove the ALLOCATABLE aspect, NAG Fortran complains:
Error: U508187A.f90, line 104: Ambiguous specific type-bound procedures ADD_P and ADD_P for type-bound generic OPERATOR(+) in type C
Ok, at least this makes more sense than the gfortran message. I could be convinced that this is in fact not allowed. Even though the declaration in the abstract type p specifies the same procedure, it IS extending the generic and you then have two procedures in the generic for the same operation. Because they specify the same procedure, I guess that is ambiguous, though the wording of the standard doesn't explicitly exclude this.
More investigation is needed - and I will escalate the missing error for the allocatable elemental function value.
Steven_L_Intel1
Ah, the ELEMENTAL error was already filed as issue DPD200247686.
FortranFan
Thanks Steve.  The point about ELEMENTAL attribute makes sense - I think I've seen the forum topic and the issue ID, but I forgot about that.
Re: the type incompatibility error:
                            1                           2
gfortran 4.9 doesn't raise that, nor does Intel Fortran.  Perhaps it is a bug in gfortran that got fixed in 4.9?
Steven_L_Intel1
Possibly - I have 4.8.
Steven_L_Intel1
Generic issue is DPD200237442.
Steven_L_Intel1
Both of these issues are fixed in 15.0 Update 2, available now from the Intel Registration Center.
FortranFan
Glad to read this,
