- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
I have a very large legacy simuilation model written Fortran 90 and compiled with the Intel Compiler. The program opens about 30 file units for writing output information and I want to make this an optional feature of the code. Is there a way through either an Intel specific command or Fortran standard that can supress writing the output files.
The brute force way would be to make some sort of flag that would be read in at run time and the place a series of IF statements before every WRITE. I would like to do this a bit more elegantly, but have not been able to figure out how (thought I could set the unit numbers to negatives, but that just caused the code to print to the cmd prompt).
The reason for all the extraneous output is for debugging the simulation model, but it impacts adversly the overall speed of the code.
Thanks for all help.
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
The main problem with collecting all your OPENs into one routine MYOPEN and then collecting all your WRITEs and all your FORMATs into a single routine...My suggestion in #2 was only about collecting the OPEN statements. Once unit numbers have been associated with bit-buckets, where the WRITE statements are located, what the I/O lists contain and the types of the members of those lists do not matter.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thanks for all the help, for my situation there are a series of global variables that are used as unit numbers and a single routine that opens them all. I think it be easiest to open up to NULL and write to that.
Can someone explain how this is done, I never knew Windows had a bit bucket like linux does.
Also, I did not follow the preprocressor directive that was mentioned. I can not set the unit numbers to 0 because the code already uses this by default for deciding which options are in use. All the unit numbers are stored in an integer array where each element represents a particular input or output file which are features that the code may use. It does use fix formats for character strings for most of the written output.
Thanks again for all your comments.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Does windows have something like a the linux tmpfs that is already mounted (no additional software needed)? One possibility I thought of would be to open the files to a directory in ram and have it constantly rewind so it does not use much storage. The main interest is both to save on the conversion to character, but to prevent excessive hard disk I/O. The code has a lot of loops that write an enormous ammount of extra data to ascii files.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
One hitch with the "all negative numbers" approach is that it then prevents you from using a rather handy feature in F2008 - the NEWUNIT specifier in the open statement, which must return a negative unit number. I find fixed unit numbers an anathema (why should I have to care what specific number is in use and then need to resolve any clashes between libraries - I just want to reference a particular connection!), so something like NEWUNIT appeals to me.
If you tested explicitly against -1 then I think you are ok - from what I can tell that can never be a valid unit number. i.e. IF (LU_23 /= -1) WRITE (...
I'd be trying to cut things off in the source code like this - if you are relying on a nul device type of solution then you've still got a lot of IO overhead being incurred, even if physical disk heads aren't involved. But failing that, as Arjen said the filename for the Windows bitbucket is simply "NUL".
[fortran]OPEN(UNIT=10,FILE='NUL',ACTION='WRITE')
WRITE (10,"('No one will read this!')")
CLOSE(10)[/fortran]
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
If you are dong a global edit and extending coding line lengths, you have to be using free-format if you are to avoid going beyond column 72 problems.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
If 0 in your units table indicates something special in addition to not being open, and if -n is not appropriate (re NEWUNIT), then you can define a unit number that is to be reserved to indicate file not available - avoid WRITE. Perhaps you can use 9999 (assuming your unit numbers are held in something other than integer(1)).
INTEGER, PARAMETER :: AvoidIO = 9999
IF(YourUnit != AvoidIO) WRITE(YourUnit,....)
Also address OPEN, SEEK, INQUIRE, CLOSE, ...
Note, should you have a section of code containing writes
IF(YourUnit != AvoidIO) THEN
WRITE(YourUnit,....) ...
ENDIF
The relative small amount of work spent now will be returned later by shorter run times in not formatting data sent to NUL
Jim Dempsey
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I like the idea of writing to the null device. It goes well with a test for skipping writing as well:
[fortran]program p
implicit none
integer unit1, unit2
! Or 'NLA0:' if you prefer
character(20), parameter :: nulfilename = 'NUL'
character(20) filename
open(newunit=unit1,file='f.txt',status='replace')
open(newunit=unit2,file=nulfilename)
write(unit1,'(a)') 'Should appear in f.txt'
write(unit2,'(a)') 'Should not survive'
inquire(unit=unit1,name=filename)
write(*,'(a)') 'Name of unit1 file = '//trim(filename)
inquire(unit=unit2,name=filename)
write(*,'(a)') 'Name of unit2 file = '//trim(filename)
if(filename /= nulfilename) then
write(unit2,'(a)') "This shouldn't have happened"
else
write(*,'(a)') 'Writing to unit2 skipped'
end if
end program p[/fortran]
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
