I am porting a large Fortran program from Intel IFORT compiler 2019.5 to the latest IFX compiler 2025.1.1.
Rough program structure: a static library in Fortran which is referenced by use statement in many modules. With the IFORT compiler it was no problem if a dependent module also used the static library, no circularity was reported.
Now, with the IFX compiler I am getting this error:
internal error: Please visit 'http://www.intel.com/software/products/support' for assistance.
catastrophic error: Internal Compiler Error: Ref module: ffe_cl.c”
Is there a linker or compiler option I am missing here for the new compiler so the static library can be used in any module? Using VS2022, Windows 11. So far I am just using basic compiler settings - as recommended in the Porting Guide for Intel Fortran Compiler.
Or do I need to change the static lib into a DLL or rework the code to avoid circularity?
Any suggestions welcome! Thank you for you help!
Thank you Arjen and Jim for your input!
It turned out a submodule (the only one in the code base) was causing the catastrophic error. Originally, the submodule was created to avoid circular dependencies but maybe as mentioned before does IFX handles this stricter. The error message was just not helpful
Anyway, I have restructured and removed the submodule, all compiling fine now.
The rough structure you describe should not lead to any circular dependency. If there is such a circularity, it could be that ifort did not detect it and was happy to build the program. ifx is definitely handling the program in a different way and seems to choke. Could any of the tools mentioned in this thread help to unravel the dependencies (if that is indeed the problem)? https://fortran-lang.discourse.group/t/module-dependencies/1194
ifort defaulted to /Qipo-
ifx (from postings on this forum *** but contra-specified in the document) defaults to /Qipo (multi-file IPO)
Try adding /Qipo- to command line (or appropriate properties in the MSVS project file)
Jim Dempsey
