- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
When compiling and running the attached code sample with ifx 2025.0.4, one gets a bogus floating point exception. Please note that code works well in numerous versions of gfortran, ifort 2021.1.2, ifort 2021.13.0, ifx 2024.2.0 and others, with and w/o check and debug options.
$ make -f Makefile.txt FC=ifx clean main && ./main
rm -f ext_mod.o ext_mod.mod calcdiff.o main.o main
ifx -m64 -fpp -fpe0 -traceback -debug minimal -O2 -fp-model strict -fp-speculation strict -fimf-arch-consistency=true -c ext_mod.f90
ifx -m64 -fpp -fpe0 -traceback -debug minimal -O2 -fp-model strict -fp-speculation strict -fimf-arch-consistency=true -c calcdiff.f90
ifx -m64 -fpp -fpe0 -traceback -debug minimal -O2 -fp-model strict -fp-speculation strict -fimf-arch-consistency=true -c main.f90
ifx -m64 -fpp -fpe0 -traceback -debug minimal -O2 -fp-model strict -fp-speculation strict -fimf-arch-consistency=true -o main ext_mod.o calcdiff.o main.o
forrtl: error (65): floating invalid
Image PC Routine Line Source
libc.so.6 00007F5E5800F520 Unknown Unknown Unknown
main 0000000000405FCB calcdiff 20 calcdiff.f90
main 0000000000406273 main 16 main.f90
main 000000000040517D Unknown Unknown Unknown
libc.so.6 00007F5E57FF6D90 Unknown Unknown Unknown
libc.so.6 00007F5E57FF6E40 __libc_start_main Unknown Unknown
main 0000000000405095 Unknown Unknown Unknown
Aborted (core dumped)
The only thing that can lead to an fpe here is a division by zero via pp. The error happens in an IF-block that shields from the division by zero (line 4 in the sample below).
pp = max( zppart(ic,izs), zppart(ic,izt) )
vdiff = 0.d00
if (pp > 0.d00) then
vdiff = cdiffc(ic) * abs( zppart(ic,izs) - zppart(ic,izt) ) / (pp*vlen(iv))
endif
The compile flags shown above are the most restrictive I could gather from the documentation, but all flags I tried that involve -O2 do fail (see Makefile.txt, named such because a file named Makefile can not be uploaded) . Only -O1 or -O0 work with ifx 2025.0.4.
ifx 2025.0.4 fails in numerous other places in our code base even when compiled with the above strict compile flags. That sometimes involves similar simple places like:
IF (T.LE.1200.D00) THEN
TC = T - 273.D00
CP = funcTC(TC)
ELSE
TCL = 1200.D00 - 273.D00
CP0 = funcTCL(TCL)
P = MAX(0.D0,ZPART(IC,IZ))
CP = CP0 + (T - 1200.D00)**(funA(P)) * EXP(funB(P))
ENDIF
where the else branch should actually not be reached.
If anyone could find working compiler flags with some decent optimization involved, I would be grateful.
- タグ:
- ifx
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
seems to have been fixed with ifx (IFX) 2025.1.0 20250317
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Just for your information, it was not me who accepted this as a solution. Since I can not use ifx 2025.1 under Windows, due to other issue there, I would rather return to ifx 2025.0.4, if it could be made working properly.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I have run into a similar issue - the vectorizer is generating incorrect code and dividing *even* when the if-condition would protect such a division. I have a smaller minimum failing example - compiling with
ifx -O2 test_divpd.f90 -fpe0 -unroll=0 -xCASCADELAKE
produces the exe with the incorrect divide-by-zero behaviour. The "unroll=0" is required to force the compiler to generate vectorised code; otherwise, the loop gets unrolled completely and the bug is not hit. Notably, the bug only manifests when different arrays are used in the if comparison and the denominator for the division.
This bug is only present in 2025.0.4 and not present in 2022.0.0, 2022.1.0, 2022.2.0, 2023.0.0, 2023.2.0, 2024.0.2, 2024.2.0, 2024.2.1, 2025.1.1 (all other installed versions that I tested on NCI gadi). I am getting around the bug by using the compiler flag -fpe3 within the build system.
(I can not use the 2025.1.1 because I get a separate ICE when compiling with it. )
Please let me know if you need any further info.
Cheers!
Manodeep
