29282 Discussions
bogus floating point exceptions with ifx 2025.0
Dandy_E_
When compiling and running the attached code sample with ifx 2025.0.4, one gets a bogus floating point exception. Please note that code works well in numerous versions of gfortran, ifort 2021.1.2, ifort 2021.13.0, ifx 2024.2.0 and others, with and w/o check and debug options.
$ make -f Makefile.txt FC=ifx clean main && ./main
rm -f ext_mod.o ext_mod.mod calcdiff.o main.o main
ifx -m64 -fpp -fpe0 -traceback -debug minimal -O2 -fp-model strict -fp-speculation strict -fimf-arch-consistency=true -c ext_mod.f90
ifx -m64 -fpp -fpe0 -traceback -debug minimal -O2 -fp-model strict -fp-speculation strict -fimf-arch-consistency=true -c calcdiff.f90
ifx -m64 -fpp -fpe0 -traceback -debug minimal -O2 -fp-model strict -fp-speculation strict -fimf-arch-consistency=true -c main.f90
ifx -m64 -fpp -fpe0 -traceback -debug minimal -O2 -fp-model strict -fp-speculation strict -fimf-arch-consistency=true -o main ext_mod.o calcdiff.o main.o
forrtl: error (65): floating invalid
Image              PC                Routine            Line        Source
libc.so.6          00007F5E5800F520  Unknown               Unknown  Unknown
main               0000000000405FCB  calcdiff                   20  calcdiff.f90
main               0000000000406273  main                       16  main.f90
main               000000000040517D  Unknown               Unknown  Unknown
libc.so.6          00007F5E57FF6D90  Unknown               Unknown  Unknown
libc.so.6          00007F5E57FF6E40  __libc_start_main     Unknown  Unknown
main               0000000000405095  Unknown               Unknown  Unknown
Aborted (core dumped)
The only thing that can lead to an fpe here is a division by zero via pp. The error happens in an IF-block that shields from the division by zero (line 4 in the sample below).
      pp = max( zppart(ic,izs), zppart(ic,izt) )
      vdiff = 0.d00
      if (pp > 0.d00) then
         vdiff = cdiffc(ic) * abs( zppart(ic,izs) - zppart(ic,izt) ) / (pp*vlen(iv))
      endif
The compile flags shown above are the most restrictive I could gather from the documentation, but all flags I tried that involve -O2 do fail (see Makefile.txt, named such because a file named Makefile can not be uploaded) . Only -O1 or -O0 work with ifx 2025.0.4.
ifx 2025.0.4 fails in numerous other places in our code base even when compiled with the above strict compile flags. That sometimes involves similar simple places like:
IF (T.LE.1200.D00) THEN
   TC = T - 273.D00
   CP = funcTC(TC)
ELSE
   TCL = 1200.D00 - 273.D00
   CP0 = funcTCL(TCL)
   P = MAX(0.D0,ZPART(IC,IZ))
   CP = CP0 + (T - 1200.D00)**(funA(P)) * EXP(funB(P))
ENDIF
where the else branch should actually not be reached.
If anyone could find working compiler flags with some decent optimization involved, I would be grateful.
Dandy_E_
seems to have been fixed with ifx (IFX) 2025.1.0 20250317
Dandy_E_
Dandy_E_
Just for your information, it was not me who accepted this as a solution. Since I can not use ifx 2025.1 under Windows, due to other issue there, I would rather return to ifx 2025.0.4, if it could be made working properly.
Manodeep
I have run into a similar issue - the vectorizer is generating incorrect code and dividing *even* when the if-condition would protect such a division. I have a smaller minimum failing example - compiling with
ifx -O2 test_divpd.f90 -fpe0 -unroll=0 -xCASCADELAKE
produces the exe with the incorrect divide-by-zero behaviour. The "unroll=0" is required to force the compiler to generate vectorised code; otherwise, the loop gets unrolled completely and the bug is not hit. Notably, the bug only manifests when different arrays are used in the if comparison and the denominator for the division.
This bug is only present in 2025.0.4 and not present in 2022.0.0, 2022.1.0, 2022.2.0, 2023.0.0, 2023.2.0, 2024.0.2, 2024.2.0, 2024.2.1, 2025.1.1 (all other installed versions that I tested on NCI gadi). I am getting around the bug by using the compiler flag -fpe3 within the build system.
(I can not use the 2025.1.1 because I get a separate ICE when compiling with it. )
Please let me know if you need any further info.
Cheers!
Manodeep
