Syntax error
Adrian_F_1
Why is the compiler expecting only 2 entries when I have specified length 7?
program ttt
implicit none
CHARACTER(16) :: CCPROP(7) = &
( 'Viscosity', 'Therm Cond', 'Elec Cond', 'Surf Tension', 'Intfacial Tens', 'Self Diff', 'Mutual Diff' )
end
D:\test>ifort char.for /free
Intel(R) Visual Fortran Compiler Professional for applications running on IA-32, Version 11.1    Build 20100414 Package ID: w_cprof_p_11.1.065
Copyright (C) 1985-2010 Intel Corporation.  All rights reserved.
char.for(4): error #5082: Syntax error, found ',' when expecting one of: )
compilation aborted for char.for (code 1)
I thought this syntax was valid, but changed to DATA and it worked OK.  Is this syntax not valid?
You have the wrong syntax for an array constructor. It should be either (/.../) or [...].
John_B__Walter
What was your intent with this statement? Its complaining about your syntax. the use of the "=" suggests that you were intending it to be a PARAMETER statement, but you've left out that key word. If that was your intent, then change it to CHARACTER(16), PARAMETER :: CCPROP(7) = & [ 'Viscosity', 'Therm Cond', 'Elec Cond', 'Surf Tension', 'Intfacial Tens', 'Self Diff', 'Mutual Diff' ] or CHARACTER(16), PARAMETER :: CCPROP(7) = & (/ 'Viscosity', 'Therm Cond', 'Elec Cond', 'Surf Tension', 'Intfacial Tens', 'Self Diff', 'Mutual Diff' /) and it will declare CCPROP(7) as parameters with the 7 values.
John_B__Walter
If an array constructor, then what Steve said. Your delimiters were wrong.
Adrian_F_1
Sorry yes I did originally have PARAMETER there, but removed it trying to figure out syntax. Thanks for the responses.
It could be a variable initialization - doesn't have to be PARAMETER.
