System Command in Fortran
katejohnso
I am having trouble with the System command in my code. The specific line is:
I1 = SYSTEM('Simulation < c:\\data\\simu.dat')
Which, if I understand correctly, recognizes Simulation as Simulation.exe located in the working folder and simu.dat is the main file read by Simulation and runs Simulation.exe as if opening the exe on the desktop. However, I get a message when debugging that says 'the system cannot find the file specified." I've heard that the SYSTEM command is very compiler specific, but that's about all the information I've been able to find. Has anyone used this before?
IanH
That error is more likely because the file C:\data\simu.dat cannot be found. Does it exist?
katejohnso
Sorry, my mistake. The file had been renamed so you're right, it couldn't be found. The error message is actually 'Simulation' is not recognized as an internal or external command, operable program or batch file.
Are you sure that simulation.exe is in the default folder? This would be the project folder if running from within Visual Studio. Maybe try replacing the string with "DIR" and see what you get.
katejohnso
The file was not located in the correct subfolder, however I moved it down and now I am getting an error that says Program Exception - Breakpoint which when I've gotten it before means it can't locate the file. However, according to "DIR," all the files are located in the correct location. Is there another reason I might be seeing this error?
Look at the console window for a more detailed error message, such as array out of bounds, etc. It may be hidden behind the debugger window.
