29386 Discussions
fortran return a different value respect to the one expected
afylot1
I checked with a debugger that a value of a variable(the name of the function) is computed, but then a different value is returned. I'd think this is related to type translation, but I don't see how. I have the following function.
double precision function func_energy(temp)
use func_params
implicit none
double precision energy_f_temp, temp
func_energy = energy_f_temp(temp, density) - p_invert
return
end function func_energy
func_params has been declared as the following
module func_params
double precision, save :: p_invert
double precision, save :: density
end module func_params
I checked that the initialization of func_params is correct. When I am inside func_energy I found that
is equal to -42476827268725768, but then when I check at the next line the value of func_energy I get 588030290385264, and this is the value that is returned by the function. I don't understand what is going on. It looks to me that everything is double precision. What could be going wrong here?
I'm using ifort with compiler option:
-g -O0 -check bounds -warn all -traceback -align all -align rec8byte
These functions are part of a fortran library that I am calling from a C main program. I have read somewhere that when the calling convention are not right you could be corrupting the stack. Does it apply here? The point is that the error appeared suddently.
thanks
Calling convention mismatch does not apply here. How is energy_f_temp declared? If it is not also double precision, you could have this problem.
Without a complete source we can build and run, it's very difficult to diagnose the problem. I'd suggest putting energy_f_temp and any other functions you call in a module and USEing that module, instead of relying on implicit interfaces., to make sure that everything is ok. -warn all will give you generated interface checking, but if you compiled the called routine later it would not pick that up.
