29369 Discussions
System and SystemQQ: what am I doing wrong?
Barbuto__Fausto_Arin
I want to do something that is quite simple (I reckon).  I must go up one folder level, chdir to another folder and then delete one existing file in this latter folder.  What I'm doing is the following:
         Logical :: I
         I = SystemQQ('cd ..\Data\')
         I = SystemQQ('del CPG.dat')
However, it seems that not even the first command works, I mean, I cannot go up one level and then into the Data folder.  The command System (by the way, in what it differs from SystemQQ?) doesn't work either.  Same result if I split the first command:
         I = SystemQQ('cd ..')
         I = SystemQQ('cd Dados')
What am I doing wrong?  My system's specs are appended below.
Thanks a lot for any help.
Fausto
Windows 7
Microsoft Visual Studio 2005
Version 8.0.50727.867  (vsvista.050727-8600)
Microsoft .NET Framework
Version 2.0.50727 SP2
What you are doing wrong is expecting effects from a call to SYSTEM or SYSTEMQQ to persist across calls. They don't. Each call to these routines (or to the standard EXECUTE_COMMAND_LINE) spawns a new process to execute the command. For things that change the environment, such as 'cd', the effect is only for that spawned process and disappears when the call returns.
Instead you need to modify the running program's environment and you can do that using the CHANGEDIRQQ library routine. Or you can put the relative path in the file specification. I would also suggest that DELFILESQQ is a preferable way to delete files.
DELFILESQQ worked well.  No extra gyrations needed.  Thanks a lot.
Fausto
One thing that I forgot to mention was that the following command:
I = SystemQQ('del ..\Data\CPG.dat')
doesn't work either, and in this case things don't seem to be a matter of 'persistence' as everything I wanted to get done is condensed in one single command.  Whatever happened above?
Fausto
C:\Projects\Lib1>type t.f90
use ifport
iret = SYSTEMQQ('del ..\Data\CPG.dat')
print *, iret
end
C:\Projects\Lib1>dir ..\Data\CPG.dat
 Volume in drive C is OSDisk
 Volume Serial Number is 6E33-836D
 Directory of C:\Projects\Data
06/30/2015  05:03 PM                 4 CPG.dat
               1 File(s)              4 bytes
               0 Dir(s)  712,683,151,360 bytes free
C:\Projects\Lib1>ifort t.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Inte
l(R) 64, Version 15.0.3.208 Build 20150407
Copyright (C) 1985-2015 Intel Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 12.00.31101.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:t.exe
-subsystem:console
t.obj
C:\Projects\Lib1>t.exe
           1
File Not Found
C:\Projects\Lib1>
