I am using Intel fortran compiler 10.1 to develop user defined feature in LS-DYNA (LS-DYNA still doesn't support the newer versions) with Microsoft Visual Studio 2008 on a Windows 7 Intel Xeon workstation. I was wondering if I could call an external .exe file (this .exe file will perform some numerical computation) from my fortran code in LS-DYNA. If so, could you please let me know appropriate command / function for this purpose, as for example, https://software.intel.com/en-us/fortran-compiler-developer-guide-and-reference-system? I didn't find documentation for Intel Fortran 10.1 unfortunately. If anyone could share it, I would appreciate that.
You almost certainly can use newer versions of the compiler with LS-DYNA. Often these third-party library developers never bother to update their documentation or test with newer versions.
You can use SYSTEM, but should add USE IFPORT to make it available. Here's an example from the manual:
USE IFPORT
INTEGER(4) I, errnum
I = SYSTEM("dir > file.lst")
If (I .eq. -1) then
errnum = ierrno( )
print *, 'Error ', errnum
end if
END
The call will not return until the program you specify finishes.
